AC Still not working
Old Jan 24, 2005 | 11:14 PM
barebackjake's Avatar
barebackjake
got the r134a recharge kit. gauge says its overfilled. do the trucks have an overlimit switch on the ac that shuts it off? the compressor wont come on at idle but will kick on when your moving and will work for a few and shut back off. i dont know what else to look for now......
jake
Old Jan 24, 2005 | 11:39 PM
Navistar444's Avatar
Navistar444
The pump should kick on at idle, and will cycle while operating. Check the wire connectors at the pump. On mine the one plug was loose and was causing a malfunction. Just grab the plug while running with ac on and wiggle the wires. It could also possibly be the ac clutch relay acting up.
Old Jan 24, 2005 | 11:54 PM
Kwikkordead's Avatar
Kwikkordead
jake
Yeah, I'm not sure, expert at VW here.
However.... there is a high pressure switch that may be malfunctioning.
Not sure about Fords, but Audi's have a thermal capillary switch that has the capillary tube inserted into the evaporator that cuts out the pump if the evaporator gets too cold. If it fails it will make the compressor shut off too soon. Cycle on and off rapidly.
VA250SD
May 12, 2012 11:58 AM
VA250SD
Aug 9, 2011 12:08 PM
keyul
1997 - 2003 F150
Mar 9, 2011 02:55 PM
chi6488
6.4L Power Stroke Diesel
Jun 17, 2009 11:33 AM
rellez
Aug 3, 2007 08:34 AM
