Trick Flow 347
Old Jan 24, 2005 | 08:29 PM
1970Custom's Avatar
1970Custom
Question Trick Flow 347
I was going throught the latest Summit Racing mag and found an engine kit by Trick Flow for the 5.0 that offers 350 HP and 370 Ft/lb of torque.
What I want to know is, does this kit work with all E.F.I 5.0s or just certain ones.
Thanks,
Eric
Old Jan 24, 2005 | 09:13 PM
Blurry94's Avatar
Blurry94
It will largely on the casting they are using. Some things may or may not be compatible like a using a factory roller cam, lifters, spider, dogbones, etc... I would call Summit and ask, that way you know for sure.
Old Jan 24, 2005 | 10:09 PM
stevef100s's Avatar
stevef100s
It probably needs mass air to run right. Not speed density.
Old Jan 24, 2005 | 11:16 PM
1970Custom's Avatar
1970Custom
Is there a way to convert over to mass air, and what is the actual difference?
Old Jan 25, 2005 | 05:05 PM
stevef100s's Avatar
stevef100s
Speed density feeds fuel and adjusts timing to set parameters, and can't adjust for large changes that go with performance engine building. Some guys have had good luck with making speed density work, but you have to know what you're doing. Mass air let's the fuel and timing adjust itself, to go with the actual requirements of the engine. Sometimes larger volume injectors are even needed with mass air. Some vehicles did come with mass air, and you didn't say what vehicle you want to build this engine for. Mass air casn be retro fitted from other vehicles, or a kit can be purchased to swap over to mass air, using an aftermarket harness and stock or performance parts.
Old Jan 25, 2005 | 06:36 PM
1970Custom's Avatar
1970Custom
The engine I'm going to build is the 302 in my 93 f-150, I say that kit and it offered adaquate torque which I thought would be great for a truck.
Old Jan 25, 2005 | 07:13 PM
stevef100s's Avatar
stevef100s
Yeah, your truck is speed density. That's a good kit for power, but won't work well for you, unless you know a speed density specialist, or convert to mass air.
Old Jan 26, 2005 | 11:48 PM
1970Custom's Avatar
1970Custom
Do you know of any kits out there that are a good choice for my truck???
How hard/whats involved with a mass air/speed density swap???
I heard that ford injectors are color coded for what p.s.i they are? if this is true what is the color of stockers (mine are orange by the way) or was the guy feeding me a load of bull??
Thanks,
Eric
Old Jan 27, 2005 | 12:04 AM
gamble71's Avatar
gamble71
I've been into 5.0 mustangs for quite a while and svo makes a kit to convert from speed density to mass air. It isn't cheap, but you know the saying " If you wanna go fast...". To build that much power you'll also have to upgrade to a larger M.A.F. and throttle body, and most likely 24lb/hr injectors... stock is 19lb/hr. The increase amazing, but you have to fork over the cash.
Old Jan 27, 2005 | 12:47 PM
Ian F's Avatar
Ian F
Another reason it won't work is the kit is meant for a 5.0 H.O. engine and ECM, which has a different firing order than the truck 5.0. You would need to convert the engine management to a H.O. system (I day-dreamed about putting one of these in my van...)
Old Jan 27, 2005 | 03:34 PM
ponytruck's Avatar
ponytruck
they sell a kit at jegs made by ford racing,bolt-on easy for 5.0s and 5.8 trucks
Old Jan 27, 2005 | 09:00 PM
1970Custom's Avatar
1970Custom
I'm not looking for racing I'm looking for pulling power (if I'd done the research I'd have found a 3/4 of 1 ton with a big block) I keep the speed at about 70, (wow, I'm 19 and going slow I think I'm getting old ) I want umph not vroooommm.
ericboj
Oct 5, 2014 02:40 PM
FordYoungGun35
Apr 5, 2013 01:39 PM
BlueOval5.0
Jun 24, 2008 07:15 PM
BlueOval5.0
International Region
Aug 27, 2006 08:17 PM
BlueOval5.0
Car/truck Buying Advice
Apr 14, 2006 06:12 PM
