Final build ideas, last thread about it promise
Old Apr 5, 2013 | 10:10 AM
FordYoungGun35's Avatar
FordYoungGun35
Okay trucks in my sig, I have a block with everything minus the heads.. I'm looking at the following options:
1. Bore the block to a 306, buy one of these 2 kits 1995 FORD 5.0L/302 Trick Flow Specialties Cylinder Head Combos - Mobile SummitRacing.com
2. Bore the block to a 306, stock intake, Ford racing gt40x heads, good cam, and long tubes.
3.(probably most expensive) bore to a 347 buy a eagle rotating kit, heads and the whole 9 yards..
What will be my best option for both performance and reliability. What can I expect for total cost and performance..
Old Apr 5, 2013 | 11:18 AM
Jarryd's Avatar
Jarryd
Those trick flow heads are pretty nice, you could probably find a deal on a used set over on corral. I know I've seen them for around $800 over there.
Old Apr 5, 2013 | 12:50 PM
FordYoungGun35
whats the best option, im leaning towardss the trick flow kit.. just because thats all im lookin to do other than the headers.. will i need to do anythin to the bottom end? im sending the block to the machine shop soon
Old Apr 5, 2013 | 12:59 PM
Jarryd's Avatar
Jarryd
Depending on cam, you shouldn't need to do anything to the bottom end. With a 306 and some compression with the trick flow heads and a good cam, you shoul have some power. I know out of a mustang that gets you around 350 to th wheels. Will be a bit less in the truck obviously but definitely fun.
Old Apr 5, 2013 | 01:00 PM
Evan_P's Avatar
Evan_P
I'm not sure that cam will work well with your truck. The lobe separation is off. Should be no less than 114 unless you want vacuum issues. Wait for Conanski to post. He will be able to set you strait.
Old Apr 5, 2013 | 01:07 PM
FordYoungGun35
hmm well idk what i need to do then like i guess i could sell the cam then buy a different one..
Old Apr 5, 2013 | 01:08 PM
Jarryd's Avatar
Jarryd
Get a custom cam designed for your truck. Hence why I suggest the trick flow heads used and use the extra money to get a good cam that will meet your needs.
Old Apr 5, 2013 | 01:12 PM
lew52's Avatar
lew52
....Your 96 will have MAF , so you can run any cam you want ....
Old Apr 5, 2013 | 01:13 PM
Jarryd's Avatar
Jarryd
You need to talk to Ed Curtis. He'll make you happy if you go the route I suggest.
Old Apr 5, 2013 | 01:39 PM
Conanski's Avatar
Conanski
The truck 5.0 doesn't need an intake upgrade like the Mustang so that's money wasted IMO, I'd suggest you buy the heads alone and put the rest of the money into a basic 347 stroker assembly(doesn't need to be forged) and XE264HR cam.
stuart olson
16
Jul 31, 2017 08:50 PM
77custom408
Sep 24, 2012 11:24 PM
1984F-150_351HO
25
Apr 7, 2010 11:06 PM
ivanribic
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
13
Feb 19, 2004 03:37 PM
