1990 E150 rearend interchange
Old Jun 19, 2004 | 04:09 PM
oldhalftons's Avatar
oldhalftons
i am looking at a 90 E150 van with a bad rear 8.8" end
disregarding the ABS connection will a 8.8 rear from a 84 fullsize bronco bolt in to a van?
are the spring pads the same width apart?
Old Jun 20, 2004 | 06:30 AM
trike1946's Avatar
trike1946
I think the Bronco is the same as a pick up.
Old Jun 20, 2004 | 10:57 AM
oldhalftons
Will a pick up rear end have the same spacing as a van?
Old Jun 20, 2004 | 06:17 PM
trike1946's Avatar
trike1946
No, they are a little different. I was always told it won't work. I wanted to to something like you are thinking.
Old Jun 23, 2004 | 03:34 PM
Yakk's Avatar
Yakk
Try www.car-part.com
-J-R-
Old Jun 26, 2004 | 04:47 PM
Knightmayre's Avatar
Knightmayre
Vans are about 6" wider than the full size trucks, so the axle won't fit. Not sure about just swapping out the centre chunk, but that will be a major pain in the ***. It'll surely be easier to just change out the whole back end.
I had to pay $150 for a junkyard one about a month ago when my axles about fell out the housing (at least I found the source of the dreadful noise!). First junkyard wanted $300!
98Econoline150
Feb 16, 2017 04:36 PM
dmanlyr
Mar 27, 2012 01:46 AM
pipman76
Aerostar
May 15, 2009 06:33 PM
camarokid81
Apr 24, 2007 09:20 PM
Boyd
Apr 3, 2006 10:26 PM
