i have a 79 f-250 custom w/ a rebuilt 351m w/ only like 3200 miles on it and i have a problem w/ when i start it after the engine has sat for a day.it takes a good 20-30 mins for the engine to clearly rev.it bogs horribly down low then clears up .i was told and tried to adjust the electirc choke on the edelbrock i have and i have leaned it out. i thought it worked but still does it.now i got this truck this past summer and it was not a every day truck. the engine before blew and he got this rebuilt and has only 3200 miles on it but was done 4 years ago .so im trying to think it just needs to live and get ridden.Also it is winter now in jersey and is pretty cold out so that maybe another thing .i was thinkin of just replacing the fuel filter too just as a thought for it.im still getting fed alot of info and trying to know my truck as much as i can so if anyone has anymore options/opinions on this it would appreciated. thanks
Welcome NICK...to Ford Truck Enthusiasts! The Internet's leading Ford TRUCK and SUV Resource! The members in these forums are very knowledgeable about trucks; they will eagerly help you…with your question. If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE.
Enjoy FTE …..
We are pleased you have chosen, the best source of Fords…..there is!
See you on the boards.
Once you get it running shut it off and look into the carb while pumping the throttle lever. If you dont see some fuel spraying out you have an accelerator pump issue. The edelbrocks use a plunger style pump and I have seen them act up in cold weather when that plunger seal gets a little old and brittle.
