Wiper "bump" switch idea
Old Jul 30, 2002 | 08:56 PM
Agent86's Avatar
Agent86
I've been toying with the idea of adding a switch to the wiper electrical system that will allow me to "bump" the wipers. Many times there isn't enough rain to warrant the 'low' wiper setting, and it's a pain (and a little dangerous depending on traffic) to reach down for the wiper swich every minute or so. I would like to just have a spring-loaded switch on the door panel that I could bump to clear the windshield. Has anyone tried this before? One problem I see is that if you cut off power before the wiper reaches the top of its travel, it stops. I realize that this could be remedied using a capacitor of the correct size, but that's starting to get a little to complicated for my electrical knowledge.
-Winston
Old Jul 30, 2002 | 09:42 PM
Mil1ion's Avatar
Mil1ion
Why wouldn't you Just install an Original FORD PLUG-IN intermittent wiper system ?
http://www.clubfte.com/users/mil1ion/2cents.gif
[font color=red]Dennis
FTE Assistant Administrator
[/font]
[link: motorhaven.autoanything.com|How YOU Can Support This Site]
http://www.clubfte.com/users/mil1ion/canada_flag_animated.gif
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
[link:www.ford-trucks.com/guidelines.html|Club FTE]
http://www.clubfte.com/users/mil1ion/Minimorleytruck.JPG
[font color=blue]78 F-150 429CJ,Silver,Explorer Pkg.
64 1/2 Mustang Pre-World's Fair Car #8092
68-Mustang 289 2v-Sunlit Gold
[/font]
Old Jul 30, 2002 | 10:15 PM
rustydog's Avatar
rustydog
On my 86 I put such a switch. I put it in line with the wiper switch its self you would have to look at a wireing diagram but I wire mine so the auto park stilled worked. I also used a stock foot dimmer switch and drilled a hole but a cheap button horn would work. I used it to help clear mud when going down trails but needed it to saty on due to using a clutch.
Old Jul 31, 2002 | 09:06 AM
Agent86's Avatar
Agent86
1. I didn't know that they existed.
2. I'm sure they cost more than a simple switch, wiring, a capacitor, and some solder would.
3. It's fun to rig things up yourself (to me, at least).
-Winston
Old Jul 31, 2002 | 09:10 AM
Agent86's Avatar
Agent86
>a clutch.
Cool! Using a foot dimmer switch might be even better for me, since my truck's an automatic. Choices, choices...
-Winston
Old Jul 31, 2002 | 07:45 PM
redneckdieselmechanic's Avatar
If you wanna get the Ford intermittant wipers, Go to a junkyard and find a 83 up Ford XLT truck and reach behind the wiper switch and look for a little black box with 2 wiring pigtails comin out of it. Ya need the box and the switch, since the switch has the intermittant feature on it. You plug the box in between the switch and the wires goin to the motor itself. Make sure the box is mounted securely to prevent vibration which kills the diodes inside it. Also make sure the switch is grounded good. There's even a couple holes already drilled and threaded to mount the box on the metal frame thing behind the dashboard. This setup is stock lookin and plus you can change the speed of the motor from a wipe every 3 seconds to about 15 seconds.
Old Jul 31, 2002 | 10:39 PM
Agent86's Avatar
Agent86
Nice! I'll do that if I find one in a yard somewhere... ought to be a pretty cheap part, or free if I get enough other stuff. Thanks!
-Winston
Old Aug 1, 2002 | 12:34 AM
mustange70's Avatar
mustange70
David40
Feb 22, 2015 06:20 AM
reamer
Sep 28, 2014 07:23 PM
speedyweasel
Jan 13, 2014 08:57 AM
Mike Gudgell
Large Truck
Sep 19, 2013 04:50 PM
Rmcmorris
Aerostar
Feb 22, 2000 07:01 PM
