power stering pump ????
Hello All,
I'm thinkin it's time to change my power sterring pump, Starting to squeel at higher RPM'S or when the wheel is turned, It's in a 1977 C-class motorhome on a E-350 chassy with a 460, Any thought's or ???? Any help would be greatly appriciated, Is this an easy R&R ???
Thanks to all,
Thanks to all,
this is an easy swap, check the lines for cracks and replace as necessary.......by the way, i think you posted this in the wrong forum, you should have put this in the steering forum.....also use the search feature in the proper forum and you will find a wealth of info on this site, you just have to keep reading the results and not give up on the first page or two, you will find the answer to almost any question that can be asked about Ford trucks and motors.........happy hunting...........
