Trans. filter change?
Old Jan 23, 2005 | 04:41 AM
LeafAngel's Avatar
LeafAngel
Post Trans. filter change?
What is the recommended trans. filter change interval? I know the fluid is 30K. I have just short of 60k on my 2000 X and was considering changing the filter along with the fluid this time. Also, someone told me that ther's a drain in the TC to allow it to be drained. Is this true?
Thanks
Leaf
Old Jan 23, 2005 | 09:18 AM
Casey's Avatar
Casey
Ford does not have a recommended change on the transmission filter. Many people are changing them every other fluid change.
There were drain plugs in the torque converter until just after the start of the 2002 trucks.
HERE is how I change the fluid. It does not require a drain plug.
Old Jan 23, 2005 | 09:30 AM
RobertH's Avatar
RobertH
I changed my Fluid/Filter at 30K per the FTE procedure link. I took my filter apart to see what was in it.
I found some yellow paint specs, likely from the markings on the parts from the factory. Also, if you look at the filter in bright sunlight, you can see the slight gray coloring in the filter where the dirt is collected. Even though the filter is not real dirty, certainly I could tell where it was collecting and that build up to me says it is worth the change. Keep good flow and the tranny appreciates it! It does not take much to change it and is not that expensive, so I would recommend it every fluid change which is every 30K.
gwuister
1983 - 2012 Ranger & B-Series
May 5, 2011 03:56 AM
Headviking
Aug 6, 2010 08:20 AM
cv18sro
1997 - 2003 F150
Nov 11, 2009 12:28 AM
jomac11
Jan 29, 2009 03:17 PM
IAMFORD
Jan 16, 2006 04:47 PM
