Sponsored by: Auxito
Airconditioning problems 97' F150
Old Jan 23, 2005 | 12:27 AM
FordandSkeeter's Avatar
FordandSkeeter
Unhappy Airconditioning problems 97' F150
For the last few years I've had a problem with my airconditioning. This problem also happens with the setting of vent and so on.
When I am traveling with the vent or a/c on and I hit the gas/speed up, the air flow switches from the normal vents to the vents used to defrost the windshield. At first I thought this problem was only during use of the airconditioner, but I have found that when using the vent setting or others it happens when excelerating.
I'm dreading the summer time with a 50% airconditioner
Old Jan 23, 2005 | 12:51 AM
LxMan1's Avatar
LxMan1
Welcome to the forums
Sounds like you have lost vacuum to the canister, which I believe is in the passengerside fenderwell. It keeps vacuum on the system under acceleration when manifold vacuum drops. Check the plastic vacuum lines for cracks.
Vinford
Nov 19, 2010 09:47 AM
TomP
Jul 22, 2004 06:33 AM
v10kenj
Dec 15, 2003 03:21 PM
eastmaj
Jul 4, 2003 08:48 PM
Anhbe
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Nov 12, 2002 10:54 AM
