Water leaking into the Cab
Old Jan 22, 2005 | 11:32 PM
Ford Blue's Avatar
Ford Blue
On a 66 F-100 what are the main sources for water to be coming into the cab?
Thanks.
Old Jan 22, 2005 | 11:39 PM
opus's Avatar
opus
Open doors?
Ha....sorry, it was an....open door.
I would think door rubbers would be a big part of it.
Old Jan 23, 2005 | 03:36 AM
daveengelson's Avatar
daveengelson
As opus indicated, as the window gaskets and door seals weather, they begin to leak. If detect leak and not due to weather, then likely the heater radiator. Still available and not difficult to replace. Just need to take care with the insulation when dismantling.
dave
Old Jan 23, 2005 | 12:47 PM
Ford Blue's Avatar
Ford Blue
The water leak is just rain water with the doors shut. lol I just replaced my heater core. Are there any other areas prone to leak? Cowl vents etc.?
Old Jan 23, 2005 | 04:20 PM
Sam_Fear's Avatar
Sam_Fear
how about the windshield wipers? Is the motor mounted under the dash on a 66?
Old Jan 23, 2005 | 04:48 PM
Ford Blue's Avatar
Ford Blue
I just installed both pivot arm gaskets. The wiper motor is under the dash.
Old Jan 24, 2005 | 10:26 AM
bertha66's Avatar
bertha66
Ford Blue how are the front and back window gaskets? On my 66 F-100 I put in new window seals and the front one leaked at the lower right corner until the new rubber heated over the summer and expaned into place. Also around the back of the cab where the roof was put on the caulking was gone it leaked.
Old Jan 30, 2005 | 05:45 PM
f100-411
Guest
Posts: n/a
Cab leak
You might want to check the seal around your radio antenna.
Old Feb 2, 2005 | 10:40 AM
Ford Blue's Avatar
Ford Blue
bertha,
My front and rear windshield seals are the original seals. They have seen better days. I knew I was going to replace them. I just wanted to make sure all other possible leaks were covered and I would get all the new seals at one time and replace them at one time. Have you ever had your cowl vent leaks?
Thanks for all the help
Old Feb 2, 2005 | 03:45 PM
bertha66's Avatar
bertha66
Ford Blue,
No my cowl vents have not leaked, but the winshield did. When I put in the new front seal in it also leaked until the heat from last summer set it. Now that I have the truck down for paint I will most likely have to go trough it agin. But while I was talking it apart I fond that the caulking around the roof and back of the cab was gone.
Old Feb 3, 2005 | 07:00 AM
RaleighDad66's Avatar
RaleighDad66
With a new windshield and seal I still get leaks in driving rain from the top and bottom of the windshiled on the right side. I also get a small leak from the right wiper arm because I haven't replaced the gasket there and the curious thing is the water runs inside and down the dash brace, reaches the front lower lip of the dash, and then traverses the exact distance till it finds my leg.
dan4486
Dec 23, 2011 08:16 PM
franks87
Bronco II
Feb 18, 2011 03:03 PM
newf350
Sep 13, 2009 05:33 PM
Storm
Jan 16, 2007 07:52 AM
