I have a 2002 f150 supercab with 3:55 LS and looking into taking it out in to the 5 inches of snow we recenly got in maryland.Is This a good idea or am i going to slip all over the place?Any help would be great.
load the bed full of snow for weight, then when it gets warm it will melt away and you dont have to unload anything, thats what i do to my F-150, but i drilled holes at the front of the bed floor so the water wont be retained and induce rusting.......
you are going to slip all over the place.
I had the same setup on my '84. getting started is the hardest trouble. you'll spin and spin. once you get going, it isn't that bad. Hopefully, it isn't too muddy, and don't try climbing any hills.
If you take your time, plan your route, don't get stupid with the trottle and start slow and steady you can go anywhere in that much snow. I have had my 4x2 through some pretty hairy stuff where most guys throw it in 4wd or throw in the towel, but I shifted my manual into 1 and took my time came out fine. Have fun and let somebody know where you are going so they can get you out if you have too much fun.
my first 2 trucks were 2wd and i never thought anything of it, just have good tires, plenty of ballast, nerves of steel and a heavy right foot. now that ive got a 4x i wonder how i ever did without, now i can go around corners with it floored and get a holeshot at a trafficlight and leave everyone else behind. i do usually start out in 2wd so i know how bad it is, but have the hubs locked so when i need the front axle im all set.
theres a ton of people out there in 2 wheel drive trucks, you wont have too much trouble as long as you use your head. good tires and some weight in the back will help a lot.
