1978 - 1996 Big Bronco
Too lean bank 1
Old Jan 22, 2005 | 09:37 PM
BigRedBronc's Avatar
BigRedBronc
Question Too lean bank 1
BigRed started throwing the old 171 code. I have seen the 171/174 codes when my MAF sensor was acting up, but not the 171 alone. I am running at PRO M aftermarket MAF, so I disconnected the battery and re-installed my OEM MAF. The 171 code (mixture too lean bank 1) throws again. Took my trusty Superchips 1715 and restored the stock program (just eliminating things one at a time) and 171 code comes back. I have indications that she is running rich (exhaust will bring tears to your eyes) so I figure the PCM thinks she is lean and is dumping fuel to compensate.
I am guessing the O2 sensor at this point, any of you remember which side is Bank 1 (getting old...memory shot...afraid to think about what goes next)? Also, any other possibilities that I am overlooking?
Old Jan 22, 2005 | 09:45 PM
greystreak92's Avatar
greystreak92
Not 100% certain but it would seem to make sense that bank one would be the sensor on the driver's side since those are the first four cylinders, hence bank one of of two... the second bank being cylinders 5-8.
Old Jan 23, 2005 | 12:20 AM
Kemicalburns's Avatar
Kemicalburns
bad o2 is my guess.
Old Jan 23, 2005 | 06:03 AM
BigRedBronc
Grey, had me questioning my sanity there for a second. Went and checked my manuals to see if I had been screwed up all these years. I agree with your logic that bank 1 is probably for cylinders 1-4, but 1-4 is on the passenger side not the driver's side.
Now heaven forbid that Chilton's and Haynes could ever make a mistake
so if I am all screwed up please set me straight. Both manuals show 1-4 on passenger side with cylinder 1 right behind the alternator. If I remember correctly my underhood diagram shows the same thing.
Can't go check right now, Mother Nature having a good old time up here in Connecticut right now. Looking at the four foot snow drift where my front sidewalk used to be, I just can't wait to get to my snow shovel. Think maybe I'll call the Emergency Room first and make a reservation.
Old Jan 23, 2005 | 07:40 AM
stevef100s's Avatar
stevef100s
You are correct, Big Red. 1-4 is on the passenger side.
Old Jan 23, 2005 | 04:03 PM
greystreak92
My bad BigRed, didn't mean to make you question your sanity. When in doubt, always question mine first.
Old Jan 23, 2005 | 05:24 PM
BigRedBronc
No sweat Grey, half the time I think I am developing Alzhei...Alz...what was I saying?
Old Jan 23, 2005 | 07:14 PM
bgblktruk's Avatar
bgblktruk
Doesn't the egr tube dump back into the 5-8 side? I've had problems with that bank of valves for years now. I don't know if I'm still following the problem here but maybe that will rattle someones thought process and help. Good luck
Mike
Old Jan 31, 2005 | 07:53 PM
BigRedBronc
OK fellow Bronconians, replaced the O2 sensor on the 1-4 side (bank 1?). Still getting OBD code 171 (System too lean Bank 1). Either we are off the mark on which side is Bank 1, or I am looking for something else. Visual inspection of wires was OK, no exhaust leaks, vacuum leaks or any other signs of foul play. No driveability issues whatsoever, although BigRed seems to be running happier with the new O2 sensor (could be my imagination...or perhaps the Bronc feels better having felt wrenches applied)
Any other thoughts?
Old Jan 31, 2005 | 11:20 PM
Kemicalburns
did you disconnect the battery after installing that and let it power down for 15mins before reconnecting??
Old Jan 31, 2005 | 11:21 PM
Kemicalburns
did you disconnect the battery after installing that and let the ecu power down for 15mins before reconnecting driving for 30 mins so computer could relearn and then pull codes??
Old Feb 1, 2005 | 04:20 AM
BigRedBronc
No. I know that you must power down computer when you replace the MAF Sensor, but I have never run across that recommendation for an O2 Sensor. What the heck, I'll give it a try. Thanks KB.
Old Feb 1, 2005 | 08:08 AM
Kemicalburns
be sure to drive it for awhile to right after this way everything gets nice and warm.
how old are your plugs? it might not hurt to throw in a new set just for sake.
Old Feb 1, 2005 | 07:09 PM
BigRedBronc
Plugs only a few months old. Nice and warm a relative term in Connecticut right now. Anything above 20 degrees is a heat wave. Disconnected battery for about 40 minutes this morning, now we wait and see.
