best method to fix motor mount??
Old Jan 22, 2005 | 08:47 PM
the tank's Avatar
the tank
To sum up what happened.......
Lead foot+3000lbs cargo+tire hop+390 4v= Blown motor mount, lol
Now I am looking at hows this going to get fixed and I thought I'd come here to pick up some tips n'tricks from the gurus of FTE that might make the job easier.
Another question..... Since I'm pretty sure tire hop killed the mount how would I go about reducing tire hop?? Allotta times I gotta peel some rubber to get the job done so it's something I can't really abstain from,
Old Jan 22, 2005 | 09:11 PM
heep70's Avatar
heep70
Jack the engine up and replace it.
http://www.4x4wire.com/jeep/tech/susp/axlewrap/
Old Jan 22, 2005 | 09:28 PM
JimR500's Avatar
JimR500
It may not need saying but here goes anyway: when putting the jack under the oil pan to jack the engine, be sure to put a block between the pan and the jack. A family idiot [not me] didn't use a block and punched a hole in the pan and then pushed it up into a crankshaft journal. Also pay attention to what's between the top, rear of the engine and the firewall as the engine is raised.
Old Jan 22, 2005 | 09:53 PM
71 Sport Custom's Avatar
71 Sport Custom
Don't forget to unbolt the remaining mount before lifting. May want to replace them both while you're under there.
Old Jan 22, 2005 | 11:04 PM
fordxxx's Avatar
fordxxx
If it has a fan shroud be sure to take it off before jacking.
Old Jan 22, 2005 | 11:43 PM
the tank's Avatar
the tank
Seems pretty strait forward, undue the tranny mount bolts too?
Thanks for the help so far, the link was good heep70,
Old Jan 23, 2005 | 06:17 AM
docholiday72tx's Avatar
docholiday72tx
Tank, Don't unhook the transmission. Just unhook the motor mount that's still good, and the shroud if you have one.
Mike
Old Jan 23, 2005 | 06:47 AM
jowilker's Avatar
jowilker
I guess I am as dumb as a chicken, but what in the hello are you trying to burn rubber with a 3000 lb load. You are lucky that a mount is all you broke?
John
Old Jan 23, 2005 | 12:49 PM
the tank's Avatar
the tank
I was actually chewing through a bunch of soft ice with chains on trying to get up the drive way, that stuff causes alota tire hop with a heavy load
Old Jan 23, 2005 | 07:36 PM
the tank's Avatar
the tank
she's fixed, hardest thing to do was getting the bolts which hold the mount to the block started.
Second79F250
Apr 27, 2012 10:56 PM
rckrwlr
Aug 31, 2011 06:03 PM
octaneforce
13
Feb 23, 2011 07:07 PM
Champ198
6.7L Power Stroke Diesel
Oct 23, 2010 04:27 PM
TheMechanicalAnimal
Apr 21, 2010 01:40 AM
