Downpipe Help
Old Jan 22, 2005 | 02:12 PM
rirwin's Avatar
rirwin
Downpipe Help
I'm about to order a DP from Tymar. I'm wondering how difficult its going to be to install. Anyone put one of these on a 94 thru 97 and can offer any advise? Can it be done in 5-6 hours? Thanks.
Old Jan 22, 2005 | 02:25 PM
Fire Rooster's Avatar
Fire Rooster
You should be able to do it easily in that time frame, you will need a saws all to cut the stock pipe out. You will need to cut in half at least once to get it out. Plus a 2x4 to bend your fire wall back a little in order to get the new larger pipe in.
Old Jan 22, 2005 | 02:30 PM
rirwin's Avatar
rirwin
I've seen where people say you need a port-power. I don'thave one and was wondering if an air hammer would fit in there to bend the firewall. You say a 2X4. You bent yours w/a 2X4?
Old Jan 22, 2005 | 03:12 PM
Fire Rooster
I actually have a 2002 PSD. But I helped a friend with his 97, we used a 2x4 and just pushed it back a little.
Old Jan 22, 2005 | 03:28 PM
rirwin's Avatar
rirwin
Thanks for the help. I crawledunder it alittle while ago and couldn't even see the seam in question. I have a silver insulation 'blanket' covering the firewall. I assume the seam is under that. The unknown makes me nervous.
Old Jan 22, 2005 | 04:17 PM
ltfox's Avatar
ltfox
Your right. The seam is under the insulation. And I used a 2x4 also to do mine. Its a little tougher but it gets the job done. Some have said that they have used a scissor jack. That sounds like it would work good also.
Old Jan 22, 2005 | 05:33 PM
444dieselrod's Avatar
444dieselrod
Just break out the BFH, it will work too. I just ordered a 3" a few days ago, should be here first part of next week, I will have to find this seem too and see how it goes.
Diesel Rod
Old Jan 23, 2005 | 06:29 PM
1997F-350's Avatar
1997F-350
where to order? i checked the site a week or so ago and is says under construction. so how do i get a tymar also?
Old Jan 23, 2005 | 07:06 PM
mjwhip2's Avatar
mjwhip2
509-922-8785. Give him a call, heard he (Dale) is a great guy and very good to work with.
Mike
Old Jan 23, 2005 | 08:19 PM
rirwin's Avatar
rirwin
Dale is very knowledgable and very easy to talk to. The kind of person you really like doing buisness with. If you get a recording, leave your #. He will call you back.
Old Jan 24, 2005 | 10:54 PM
1997F-350's Avatar
1997F-350
Mike
thankyou very much
Old Jan 29, 2005 | 12:28 PM
444dieselrod
Like I said erlier, I just order one from dymond eye, a two piece, 3". Yes it can be done in 5-6 hours, mine took all of 3 to cut the old one out and put in the new one. What a P.I.T.A. that was!!!!! not only is there no room, but its TIGHT to get the new one in. I do suggest taking your hood off, alot more room, get a BFH, a long 2x4 and some beverages, a few friends over to help and make a party out of it.
the results are that it now has even MORE turbo wishtle, a little less flutter not much, and a whole lot at loud when you romp it. My friends say it sounds like and old mach with all the whistle, I realy honestly think it runs hotter now for some reason???? like only 50*-100* but I was able to hit 1200* alot easier, and it took a little longer to cool down to 400* when i got in the driveway, maybe I was just hot rodding it and just thought it was hotter. either way, it was fun, and sound cool so I am happy
Diesel Rod
3Mike6
N. California Chapter
Jan 21, 2010 12:44 PM
igod69m
Jan 16, 2010 09:15 PM
69 stang
Dec 24, 2009 07:08 AM
SuperSnake
Nevada Chapter
Dec 16, 2007 04:12 PM
slmann
Missouri Chapter
94
Dec 10, 2006 09:28 AM
