Strange noise
Old Jan 22, 2005 | 01:02 PM
cherryredF-150's Avatar
cherryredF-150
Strange noise
I have a 1994 F-150 with an inline six and auto tranny. In the speed range of 65-70mph it makes a loud humming noise that seems to come from directly under the cab. My dad said it might be the universal joints going out. How do you tell if the U-joints are bad? Could the transmission or differential be making the noise? Any ideas would be appreciated.
Old Jan 22, 2005 | 01:30 PM
1081's Avatar
1081
Yes it could be in the transmission, the u-joints like dad said, the rear end or bearings, or even tires. Sometimes the joints will make a ping or clunk noise when you put it in gear or go into reverse when they start to wear. Occasionally you can park it on level ground and climb under there and see if there is play in the drive shaft. If it has a lot of miles the u-joints might be a good and fairly cheap place to start.
Old Jan 23, 2005 | 12:59 PM
cherryredF-150
Thanks for your help. I will start with the u-joints like you said.
awq134
2009 - 2014 F150
Dec 25, 2014 01:50 PM
arrow_uk
15
Jan 8, 2011 12:23 PM
KingRanchMan02
1997 - 2003 F150
Nov 8, 2006 08:46 AM
chefandy1st
Mar 19, 2005 08:21 AM
snagnever
1997 - 2003 F150
May 13, 2004 10:35 PM
