What does the "lift pump" do?
Old Jan 22, 2005 | 12:16 PM
Diesel Daddy's Avatar
Diesel Daddy
I'm just wondering, what does the lift pump do? How is it different than the fuel pump? I've heard they are classic for failing at around 100k miles. Is this true?
Old Jan 22, 2005 | 02:43 PM
dieselstroke's Avatar
dieselstroke
as far as i know its just another word for fuel pump, they are mechanical and are
activated by a rod that comes through the block that runs off a lobe on the cam
i believe. That could be true about them generally going out at 100k, some may
last longer and some may crap out sooner than that every trucks a little different.
But lift pumps are kind of old school, mine has a inline electronic pump.
Old Jan 22, 2005 | 05:57 PM
444dieselrod's Avatar
444dieselrod
Yes, it is just another name for a fuel pump, except the ones on these trucks are different from the others, they are higher pressure pumps, 50-65 psi they will build. located right on top of the engine down in the valley, right behind/under the fuel bowl. Mine has lasted the 42,000 I have owned the truck, and as far as I can tell it is the original one with 200,000+ Cross your fingers.....
Diesel Rod
Old Jan 22, 2005 | 10:15 PM
Diesel Daddy
Good Luck Diesel Rod! Mine only has 115k! Runs great, I was just wondering why it gives me a hesitation from off idle sometimes. And the other day, a stall while driving (already replaced CPS).
Old Jan 22, 2005 | 10:41 PM
sterling's Avatar
sterling
[B]TPS?????? or is that the same thing as the CPS??
Old Jan 22, 2005 | 11:13 PM
barebackjake's Avatar
barebackjake
ive got 168k on my original fuel pump.
the lift pump is more of a term on non heiu injected motors, where theres a lift to get it to 40 or so psi and an injector pump to take it to 1500 or so psi.
Old Jan 23, 2005 | 09:56 PM
Diesel Daddy
Do the 97 Powerstokes have one? Or do they just use the inline one?
Old Jan 23, 2005 | 10:20 PM
barebackjake
nope just a mechanical cam driven in the engine valley, im putting an electric pump on my truck
Diesel911
May 9, 2017 09:04 PM
gmammakn
Mar 23, 2017 09:38 PM
12valveEx
Aug 5, 2015 01:23 PM
kellar
1978 - 1996 Big Bronco
Nov 28, 2007 04:18 PM
mustangz_04
2004 - 2008 F150
23
Jul 3, 2007 01:26 PM
