1978 - 1996 Big Bronco
Fellas I need your help
Old Jan 21, 2005 | 03:50 PM
sandy clawz's Avatar
sandy clawz
Unhappy Fellas I need your help
the rear window in my bronco is stuck down. This creates alot of problems because we are about to have a two foot snow storm. Problem two is that the temp tag is on the window, What a cluster#$@! I hear these windows are infamous for freezing. I dont know if that is the problem though. Please help
Sandy
Old Jan 21, 2005 | 06:54 PM
BroncoRoadKill's Avatar
BroncoRoadKill
Well, I would start by checking the switches does it not work with either, by key on back of tailgate or in dash switch?
If not by either, then you can take the access panel off and unplug the motor and check and see if there is voltage going to it from the swiches, if yes, then apply power directly too the motor and see if it runs.
Good luck.
Old Jan 21, 2005 | 06:58 PM
MatthewC's Avatar
MatthewC
Use the search function in this forum. There is so much info on the rear tail gate window, that you should easily find the answers you need.
-Matt
Old Jan 22, 2005 | 10:23 AM
sandy clawz
Thumbs up Thanks, I got it
I had a friend come over who has a big old GMC, he says they all have problems with freezing. We managed to force the gate opened. As it fell you could hear the ice crack. We forced it up and the window worked. We think it may have also been the saftey catch that does not allow the window to move when the gate is partialy opened. Either way we got it. Thaks alot for your help guys.
Sandy
Old Jan 23, 2005 | 04:53 AM
Black Ford XLT's Avatar
Black Ford XLT
switches
Dash mounted switches are a problem with my 1992 bronco. (Go bad) TR
Hwyman3
Maryland Chapter
60
Aug 20, 2011 03:08 PM
1975Ford
Garage & Workshop
May 31, 2006 12:24 PM
1975Ford
May 26, 2006 08:35 AM
GaryJ
General Automotive Discussion
Jun 26, 2005 01:23 AM
foddoch
15
Jun 15, 2005 09:02 PM
