thermactor system; smog pump
Old Jan 21, 2005 | 01:31 AM
ratchetgmc's Avatar
ratchetgmc
I am new to this site and already enjoying it very much. have a 92 f-150 5.8l and ready for new cats and exhaust.time for a tune up also and disgusted with the thermactor engineering placement. read all post for removal and this is not my choice for dealing with the problem.looking now to relocate some items; specifically the air bypass valve. metal tubing is very much in the way for spark plug removal and hose out the back to the diverter valve in the way for checking transmission fill level. can the air bypass valve be installed on its side or upside down. thanx for all help in advance. great site.
Old Jan 21, 2005 | 11:04 PM
broken wire's Avatar
broken wire
valve can be installed in any position, there is nothing that can fall out of place if turned upside down or sideways. Just keep the connections on the same ports and the same size hose.
Old Jan 28, 2005 | 03:32 AM
ratchetgmc's Avatar
ratchetgmc
Thank you for your reply broken wire. I felt as if it could be but was not sure how the valve operated. If it was a spring return i did not know it would not return properly.
I was also told to not use rubber for my lines because if the check valve at the back of the heads failed; too much rubber would be a large fire. ford techs told me they have seen these check vavles fail and the rubber hoses catch fire; minimal rubber so small fires that burn out.
Old Jan 28, 2005 | 07:12 AM
bobcf's Avatar
bobcf
great info, thanks to both of you.
Bob
AsianSpanker
'80-'86 FAQs (Frequently Asked Questions)
19
Mar 23, 2020 10:52 PM
vjsimone
Mar 13, 2019 08:53 PM
variant13
May 16, 2015 08:59 AM
Parsedout
20
Apr 12, 2015 12:18 PM
whisler
Dec 13, 2011 11:50 PM
