four cylinder problem
Old Jan 22, 2005 | 02:39 PM
pcatanza's Avatar
pcatanza
Could the capacitor on the coil pack be the problem??
Does each set of plugs and coil pack have a separate purpose??
Old Jan 22, 2005 | 05:31 PM
el conquistador's Avatar
el conquistador
Originally Posted by pcatanza
I cleared the codes last night and rechecked them this morning.
This is the codes in order.
18
28
31
88
I don't know if it matters, the problem is on my 91 Ranger, standard cab, 5 speed manual transmission.
Any ideas.
my haynes manual says:
18- erratic IDM input to the processor
28- Loss of IDM-right side
31- EVP circuit below minimum voltage
88- Loss of dual plug input control
my scanner manual says:
18- Loss of TACH signal to ECA
-or-
DIS Fault-primary circuit failure in coil 1,2,3, or 4
-or-
EDIS fault-failure in SAW circuit
28- EDIS fault- failure in coil 3 primary circuit
-or-
DIS fault-loss of right side TACH signal
31- EVP sensor- signal boltage is below minimum specification.
-or-
EGR valve is not in its normal closed position
88- DIS problems- loss of dual plug control
looks to me as though you should start trouble shooting the distributorless ignition system (DIS)
for code 31 you may just need a new evp sensor, about $30.
Old Jan 22, 2005 | 06:13 PM
pcatanza's Avatar
pcatanza
Any tips on trouble shooting the distributorless ignition system (DIS)
My understanding of how this system works is limited.
Old Jan 22, 2005 | 09:14 PM
el conquistador
check this link out:
https://www.ford-trucks.com/lc/lc.ph...Diagnostic.doc
Old Jan 23, 2005 | 09:41 AM
pcatanza's Avatar
pcatanza
Great info
I will check everything today and let you know what the results are.
Thanks for all of the help.
Old Jan 24, 2005 | 08:34 PM
pcatanza's Avatar
pcatanza
Good News.
It appears that my problem was the EDIS Module.
I replaced it and my truck ran smooth today.
