i have a 1974 f-100 with a 300 six i want to swap the motor for a 1968 302 v-8 i already have the original 4spd i was wondering if the 302 would fit the bellhousing of the 300 sixes tranny. so i just need to know if the 4spd will adapt to the 302 v-8
Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE. We are pleased you have chosen the best source for Fords!
See you on the boards.
Enjoy FTE …..
my six has a bent crank shaft and has no oil pressure and ive allready put 100,000 miles on a bent crank . the motor is indestructable but my dad wants to give me his 302 and ide much rather have 300 hp
you should be able to buy most of the parts you are looking for off the shelf. If they do not have the motor mounts for the 302 get 351w mounts they will work and i believe they were an option for your truck. you will have to change the bell housing out on the transmission and your flywheel as the balance is not the same. Hopefully you will have all the hardware/brackets for the assesories with the 302 if not check the wrecking yard
