thermactor hole plugging update
Old Jan 19, 2005 | 06:39 PM
hey_beaver's Avatar
hey_beaver
Red face thermactor hole plugging update
well i went to a machine shop to see about plugging thermactor holes in my 351m heads. the machinist took them and simply welded the holes that flow into the intake closed. took 10 minutes and cost me 20 dollars hope i did it right. I trusted the machinist cause i couldnt get any responses to my previous post on this subject. I'm sure I'll have several people tell me how to do now but thanks anyway. but if there is a problem with this method would appreciate input on it
Old Jan 20, 2005 | 04:51 PM
TxBrokenarrow's Avatar
TxBrokenarrow
hi...might be dumb question,but why would you do that??just asking because i'm fix'in to have my heads r&rd..
Old Jan 20, 2005 | 05:46 PM
hey_beaver's Avatar
hey_beaver
because if your running an after market intake and carb with no emissions junk on it, you dont want the hot air from your exhaust passing through your intake and heating it up. the cooler your fuel system the better. so i'm told anyway. the purpose of the holes is for your factory choke system I believe. the heat from the motor tells it when to shut your hi idle off. i have a manual choke 750cfm holley double pumper so its not helping me.
Old Jan 20, 2005 | 06:36 PM
Bill_Beyer's Avatar
Bill_Beyer
The purpose of the holes which go from the intake to the exhaust ports are to allow fresh air from the A.I.R. pump to be injected into the exhaust stream. I really don't think that it'll make a huge difference in the intake temp if the exhaust gas runs backwards through the system as long as you plug the port in the intake but it can't hurt.
Old Jan 20, 2005 | 08:31 PM
TxBrokenarrow
Bill...as long as you plug the port in the intake ....are you talking about the pipe thread holes on the intake???i'm fix'in to install a weiand 8010...thanks
Old Jan 20, 2005 | 08:55 PM
hey_beaver's Avatar
hey_beaver
your thinking of the egr valve i think which the thermactors holes flow to there but the hot air still goes into your intake you need to block it where it enters I believe
Old Jan 21, 2005 | 04:08 AM
Torque1st's Avatar
Torque1st
Posting Legend
There have been other recent threads on methods to plug the thermactor ports. You can find them with the search function.
Here is one from just a couple of weeks ago:
https://www.ford-trucks.com/forums/s...d.php?t=327831
Old Jan 21, 2005 | 07:41 AM
mark a.'s Avatar
mark a.
Keep in mind if you run it in the winter it will run like crap till it gets warmed up. I used to plug them but I wont anymore. I wouldn't recomend doing it on a street motor.
Old Jan 21, 2005 | 08:26 AM
Torque1st's Avatar
Torque1st
Posting Legend
Blocking the thermactor holes is a problem unless you run a heated air intake with a stock type airbox. Running a properly functioning heated air intake gives you the best performance in all conditions. The exhaust crossover can cause carb percolation and vapor lock. It also cokes the oil on the underside of the manifold if you don't run a valley pan. The additional heat on the incoming air is bad in the summer. Running an open element aircleaner is bad most of the time, they work fine on trailer queens tho.
You can find descriptions of airbox modifications etc in the 73-9 forum as well as this one. I run a dual snorkel unit on a Mopar airbox with a modified thermostatic vacuum switch.
carbo_nero
Mar 14, 2017 09:04 PM
BigBlocker0248
Jan 20, 2016 06:41 PM
JoeBlow
May 15, 2003 12:00 AM
Superdave
Feb 10, 2002 12:19 AM
laptopgeek
Jun 7, 2001 05:12 PM
