Clutch repair
Old Jan 19, 2005 | 11:22 AM
SLM-F250's Avatar
SLM-F250
Clutch repair
I Have a 2000 F-250SD 4WD 6 speed manual transmission with 103,000 miles on it. I am planning a cross country trip this summer towing a 10,000lb 5th wheel, Should I change the clutch or not worry about it?
Old Jan 19, 2005 | 01:47 PM
rebocardo's Avatar
rebocardo
Check your clutch disc to see how much is left on it.
Old Jan 19, 2005 | 04:46 PM
rhodie's Avatar
rhodie
Don't want to steal your thread, but related: how do you know how much left is okay/worth a change--never seen a new one, so I don't know how thick they typically come.
Old Jan 19, 2005 | 05:45 PM
sixpack2639's Avatar
sixpack2639
rhodie, Most new clutch disks have grooves cut into them. If the grooves are gone it's only a matter of time before it starts slipping.SLM-F250, If you only have 103,000 on it i'd say your clutch is probably ok unless you ride it a lot or there have been some inexperienced manual trans drivers driving it.
Hope that helps, Carl
Old Jan 20, 2005 | 09:04 AM
rhodie's Avatar
rhodie
Thanks for the info Carl....appreciated.
Old Jan 20, 2005 | 09:18 AM
SLM-F250's Avatar
SLM-F250
Smile
Thanks for the help, I will check it out.
Ford_Six
May 31, 2008 07:58 AM
f100guy
Feb 18, 2008 07:44 PM
kpina
May 18, 2004 08:46 AM
Kurt Frome
17
Mar 11, 2004 07:02 PM
