Block Heater
Old Jan 17, 2005 | 10:16 PM
2cylguy's Avatar
2cylguy
Block Heater
I only use my truck once or twice a week and was wondering if it will hurt anything to keep it plugged in 24/7 ? Just during the cold winter months. Thanks, Tom
Old Jan 17, 2005 | 10:26 PM
mjwhip2's Avatar
mjwhip2
Other than doubling your electric bill there shouldn't be any problems.
Mike
Old Jan 17, 2005 | 10:49 PM
BigRed350's Avatar
BigRed350
I would tend to think that this practice could lead to problems. The block heater is essentially just like an electric water heater. It is an element that is submerged in water, or in this case, coolant. If you took a standard electric water heater and disabled the thermostat to where the element stayed on all the time, eventually the water in the tank would either begin to boil, the element itself would burn away, or the breaker on the circuit would blow from thermal overload. What would be different here? I guess my question would be, "Why would you want to?" I find that on my truck, just plugging it in for an hour or two is more than enough to warm up the engine and insure a quick start. If nothing else, then I would put a HEAVY DUTY timer on it and run it for no more than 3 hours at a time, preferably before you are going to start it. Just my opinion.
Old Jan 17, 2005 | 10:53 PM
FireMan208's Avatar
FireMan208
I work a 24/hr 2-3 times a week and when I get to work @ 8am I plug it in till 8am the next day. Never had a prob, then I only do it during the cold months too. IMHO
Old Jan 17, 2005 | 11:15 PM
BigRed350's Avatar
BigRed350
I wasn't saying that leaving it plugged in all the time would definetly lead to problems, just that it could. For one, I would think that this practice would have to shorten the heating element's life. I suppose that if I were in a situation where I had to make sure it started at 6 am and I knew it was going to be 15 degrees outside and I didn't have a timer available and I couldn't get up 2 hours early and......
Well, you get the picture, then I would leave it plugged in. But, since I have other options available to me, then I choose to only plug in a few hours before I am planning to start it.
Old Jan 17, 2005 | 11:18 PM
FireMan208's Avatar
FireMan208
Eh no biggie just thought I'd chime in is all. But how hard is it to put a timer (heavy duty) on? Let alone where should I look?
Old Jan 17, 2005 | 11:30 PM
BigRed350's Avatar
BigRed350
No big deal at all. From what I've read on here, the heater is around 1500 watts. So, if you take 1500 and divide by 120 (volts), it comes to 12.5 (amps). Most of the lamp timers I've seen at places like Home Depot or Lowe's are only rated for 600 watt loads. So, you need to get one that is rated to at least 12 amps. 15 amp rating is better. It should run you about 20 dollars or so. Then, just set it to come on 2 or 3 hours prior to when your getting off shift and all should be well. It just plugs in between your extension cord and the receptacle. As an added bonus, you will sleep much better at night knowing that you are doing your part to save the taxpayers some money that would have otherwise just been used in wasted electricity!!
Old Jan 17, 2005 | 11:48 PM
FireMan208's Avatar
FireMan208
Thank ya sir, I'll have to look into that.
Old Jan 18, 2005 | 04:56 PM
2cylguy's Avatar
2cylguy
I have timers in my home for our window a/c units and these are heavy duty timers. I would think they would work. Thanks for the quick replies.
Old Jan 18, 2005 | 10:14 PM
kawika's Avatar
kawika
I have been running my timer for about 3 hours before I leave for work, but since its been getting down to 0* or lower, I have been finding that its harder to start. I increased the timer to 4 hours and it starts up with no problems. I think I am going to leave it this way (4 hrs) from now on.
Old Jan 19, 2005 | 12:23 AM
BigRed350's Avatar
BigRed350
Just make sure they are rated for 120 volts, not for 240. The pin outs on the 240 volt receptacles and timers are different.
Old Jan 19, 2005 | 12:25 AM
BigRed350's Avatar
BigRed350
The outside temperature is really the deciding factor. When it's only in the 40's, an hour or less seems to do it. In the 20's, I need 2 hours.
Tom
Testing.....
May 4, 2014 07:41 PM
caseys
Washington Chapter
31
Jun 27, 2010 01:17 AM
SteveBricks
S. California Chapter
Jun 27, 2008 07:58 PM
Tom L.
New Member Introductions
Apr 5, 2006 05:42 AM
Vampiro
Jul 5, 2002 07:39 PM
