C4/T5 Swap
Old Jan 17, 2005 | 03:22 PM
F-Deuce50's Avatar
F-Deuce50
C4/T5 Swap
I got a '68 Cougar with a 302ci and a 3 speed C4. I am looking into swapping the C4 with a T5 manual. I would appreciate some help. I just want to know if it is possible and what are the pro's and cons.
Old Jan 18, 2005 | 07:51 AM
smoke n tires's Avatar
smoke n tires
ive seen it done on mustangs before. its harder to go from an auto to a manual because of the cable and pedal. you will need a flywheel (28oz balance) and clutch assembly. problably a different cross mem, the driveshaft will need to be cut or legthened, and your center concil will have to be modified. i think if you do it you will be happy cause you can get away with a lower rear end gear and still have top end. i have a t5 in my gt mustang with a 3.73 and i can still get to 150 mph with killer low end acceration, and 16-17 mpg.
Old Jan 18, 2005 | 11:36 AM
F-Deuce50's Avatar
F-Deuce50
Interesting, thanx mate.
Old Jan 19, 2005 | 05:21 PM
RTM's Avatar
RTM
I installed a T-5 in my 65 fastback. I made my own cable set up and I made my own cross member. Drive shaft didn't matter because I swapped to a 9 inch rear which requires the shaft to be shortened anyways.
here's a link to my web site http://home.comcast.net/~grabblue65/
TrainPRes
Jan 13, 2014 07:36 PM
GarageFab
1983 - 2012 Ranger & B-Series
Oct 19, 2010 12:12 AM
79FordBlake
May 18, 2010 05:54 PM
1984F150SB
May 25, 2009 05:43 PM
rogersdan
Jul 28, 2006 11:36 AM
