Sponsored by: Innova
Blown fuse problem...
Old Jan 17, 2005 | 01:41 PM
ChevmaninaFord's Avatar
ChevmaninaFord
I have 2 MTX 10s Thunder6000, a Pyramid 1000W amp, everything is wired correctly, but as I turn the volume up the fuse(30A) blows when it is too high, it will blow around volume level 12 and my stereo goes up to about 30. What could my problem be?
Old Jan 17, 2005 | 08:00 PM
danger_ranger_dude's Avatar
danger_ranger_dude
What gauge wire are you using? Second is it the fuse next to the battery or the one in the amp. It just sounds like you have too little of a fuse. I have a 1200 watt sony, and i use at least a 60 watt. Most automotive places will have larger fuses that just cost a buck or so. Hope that helped
Old Jan 18, 2005 | 08:11 AM
grease monkey's Avatar
grease monkey
It sounds like it may be too small of a fuse. If that dont help check and see if you are grounding out some where.
Old Jan 19, 2005 | 05:25 PM
ChevmaninaFord
Problem solved thanks guys
1sraider
19
Nov 28, 2018 04:32 AM
EppNation
Mar 19, 2015 06:43 AM
lordmatt
Electrical Systems/Wiring
Jan 9, 2012 08:45 AM
ddubya61
Nov 29, 2006 11:00 AM
JVDALLAS1
1997 - 2003 F150
Jul 1, 2002 02:59 PM
