Sponsored by: Auxito
Axle Codes
Old Jan 17, 2005 | 10:54 AM
zman764's Avatar
zman764
Axle Codes
On the rearend of my 97 4x4offroad 4.6L it has a metal tag that reads
S862B 55886K
Can any one tell me where to look to find the code for the front differential?
The other day i was pullin an 04 2wd out of some we goopey clay, first attempt i put chains on my front hooks and on his hitch, i tried to back out in 4 lo, but only my left front and right rear wheels would spin, i wasnt goin any where
So i turned around and chained up my hitch to his, and pulled out forwards in 4lo, no problem all 4 wheels were spinnin.
I dont know alot about differentials or anything of that sort. Can any one explain this to me?
Old Jan 17, 2005 | 12:13 PM
MBDiagMan's Avatar
MBDiagMan
The differentials consist of what are called spider gears. These allow the wheels to run at different speeds so that you can go around corners without one of the tires scrubbing. If you have really bad traction, the wheel on an axle that has the least resistance to rotation will spin.
In a limited slip differential there are clutches that allow a wheel to slip enough to turn corners but will apply torque to both wheels in the situation where both wheels have bad traction.
I'm sorry I can't help with the codes. I am curious to see what my ratios are also, so I will be watching for a reply. I just got the truck Saturday and have not had a chance to get underneath and check.
Good luck,
Doc
Old Jan 17, 2005 | 07:03 PM
projectSHO89's Avatar
projectSHO89
3.55 8.8" rear axle.
Steve
Old Jan 17, 2005 | 10:16 PM
kspilkinton's Avatar
kspilkinton
To add to Steve and Doc, the rear is an open differential. Code is "19" under axle on the door sticker.
The front is a reverse cut 8.8 inch 3.55 open diff, no tag required. All '97s and newer F150 4x4s have the 8.8 up front with the same ratios that are in the rear.
-Kerry
Old Jan 18, 2005 | 06:04 AM
MBDiagMan's Avatar
MBDiagMan
Okay, so I think I know where to look for the code on the sticker, but where do I go to decipher the code once I get it?
Thanks for the replies,
Doc
Old Jan 18, 2005 | 06:24 PM
PaulC's Avatar
PaulC
If the first digit is a number, the differential is open (non-limited-slip). If the first digit is a letter, it's a limited slip. The second digit defines the axle ratio. Post what you find under the word AXLE as found on the vehicle certification label on the driver's door.
Old Jan 21, 2005 | 05:07 PM
MBDiagMan's Avatar
MBDiagMan
PaulC,
Thanks for the offer to decipher my axle code.
It is H9 on the door sticker. It is a 2000 F150, short bed 4X4. I assume that the H means limited slip, but what is the ratio?
Thanks very much for the offer.
Have a great day,
Doc
Old Jan 21, 2005 | 07:42 PM
jseim44's Avatar
jseim44
3.55 Limited Slip
I've got that too, but my clutchs just have to be shot after 145,000 miles
Old Jan 22, 2005 | 10:50 AM
zman764's Avatar
zman764
Are you refering to the sticker in the door, or the metal tag on the differential?
Old Jan 22, 2005 | 10:52 AM
zman764's Avatar
zman764
The above is directed toward PaulC
Old Jan 22, 2005 | 08:16 PM
kspilkinton
PaulC was referring to the door jamb sticker, zman. The tag on the rear itself will have an "L" between the 3 and 55 on the second line for a factory limited slip. The "3" is under the bolt holding the tag on and hard to see.
Ex: 3L55 8 8 XXXX
-Kerry
Old Jan 22, 2005 | 09:44 PM
zman764's Avatar
zman764
Thank you for clearin me up kspilkinton,
Do you know if any one can translate this code for me ? Its on the metal tag on the rear diff.
S862B 55886K
I know its open, i just want to know what it all means
Old Jan 23, 2005 | 01:20 AM
LxMan1's Avatar
LxMan1
The S862B is probably the prodution date code. 55 (the 3 is hidden under the bolt) is 3.55 88 is 8.8" ring gear and not sure about the 6K. Could mean Nov.96. What is the build date of the truck?
rbrockman
All Things Towing
May 6, 2017 03:42 PM
Seaville
Jan 24, 2017 08:09 AM
jeremy_p
May 16, 2016 07:22 PM
w74bronco
Feb 9, 2014 12:40 AM
pwrstroketx
Jan 3, 2009 12:30 PM
