Help????
Old Jan 17, 2005 | 07:28 AM
joe99psd's Avatar
joe99psd
Help????
I had to take my truck to the stealership this morning. Over the weekend I developed a fluid leak that seems to be coming from the drivers side frame rail in the front wheel well. At first I thought it was brake fluid, then I thought it was power steering fluid... Turns out to be Transmission fluid??? I understand that there is a hydro-boost system that uses transmission fluid to help the power steering and power brakes??? where is this system, and would you think I have a leaky hose, or is there a possible bigger problem. My brake light did come on a couple of times this weekend........Any and all help is much appreciated
Joe
ps...
early 99 f250 4x4 psd w/170000 miles.
Old Jan 17, 2005 | 09:25 AM
joe99psd's Avatar
joe99psd
anyone?????
Old Jan 17, 2005 | 09:28 AM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
if the fluid was pink it was the trans. clear would be brake. Other than that I am lost on this one.
Old Jan 17, 2005 | 11:00 AM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Correct. The power brakes and power steering all run off the power steering pump. If it was tranny fluid...maybe the tranny cooler connections at the radiator are leaking and blowing back that side??
Old Jan 17, 2005 | 02:09 PM
joe99psd's Avatar
joe99psd
just heard from Ford... Hydro-boost pump leaking fluid. $205.00 parts $280.00 labor.....any thoughts???
Anyone replaced this part at home???
Joe
waskin27
General Automotive Discussion
Jun 30, 2013 11:21 PM
abyars111
Apr 16, 2013 05:36 PM
JJFL99PSD
Feb 2, 2004 08:33 PM
Jesters Court
Oct 7, 2003 07:46 AM
