Warranty ?
Old Jan 16, 2005 | 10:26 PM
Ford-man22's Avatar
Ford-man22
Warranty ?
Does putting on a lift kit VOID the warranty completely? I've heard that it just voids the parts that are effected by the lift kit. For example shocks, coil springs, lower control arms, bushings, swaybars and etc. Is that true? Need help!
Old Jan 17, 2005 | 02:30 AM
Monsta's Avatar
Monsta
Sit. Stay.
Not completely.
Only the parts associated with the lift can be voided. If the problem is a direct result of using the lift then the dealer can deny your warranty claim.
Eg. If your power window motor breaks he can't very well justify that the lift caused it. But if your ball joint gets toasted...well...
There are quite a few authorized dealers out there who install the lifts at their dealership. Maybe finding one of those places to do your work can set your mind at ease...
Old Jan 17, 2005 | 05:21 PM
Ford-man22's Avatar
Ford-man22
Would that include the driveline considering I'll be running bigger tires?
Old Jan 17, 2005 | 08:35 PM
mkoser's Avatar
mkoser
Yes and no. Ford-man. Technically they have to proove that your modification caused the failure to void your warranty. BUT if you are running with tires that are larger than reccomended, they may say, "Well it clearly states in your manual that you should use ______ size tire..." and "find" a way to proove that your tire modification caused the problem... The same thought can be used when one fails to recalibrate thier speedometer after a tire increase or decrease in size. If you get clocked by a state trooper doing 5 or 10 faster than your speedometer says, it doesn't matter. They can then give you a citation for defective equipment. I found it is never better to try and blame your speedometer for the problem...
I personally think that on these first new gen f150's modifications should be left to a dealership or reputable shop. That way IF something goes wrong, you can pass the blame on to them, and maybe save you some ching.
MK
Arizona SuperDuty
Feb 28, 2013 06:28 AM
74redone
2004 - 2008 F150
Nov 12, 2010 03:55 PM
cut'em
Oct 26, 2007 12:16 PM
GotLift
Feb 27, 2005 01:20 PM
fbcworship
1983 - 2012 Ranger & B-Series
Oct 3, 2004 08:10 AM
