Throttle Sticking
Old Sep 23, 2003 | 10:09 PM
Wdkask's Avatar
Wdkask
Angry Throttle Sticking
I have A 92 F150 and When the weather gets cold, my accelerator starts sticking. Not only is it stiff to start out with, so that you have to push hard to get it to start out, but it will also stick when i'm driving. I let off of the gas and it just keeps on pulling. I replaced the Throttle position sensor, Cleaned and lubed the throttle body, linkages, etc. and even brought it to the dealer service dept. They had it for 2 weeks and couldn't figure out what was wrong with it. Has anyone else had this problem, and if anyone has found the solution PLEASE LET ME KNOW!!!
Thank you "my truck"
P.s. The only way i can get it unstuck is to shift into Neutral. It will rev up real high and then come back down to normal Idle
Old Sep 23, 2003 | 10:32 PM
Vanhecht's Avatar
Vanhecht
Throttle Sticking
i think it has to do with the plastic on the linkage, mine has done the same thing, i think what happens is since it is cold it wants to stick more, also i had to use zipties to mke my linkage stay in the proper position in relation the the throttle body assembly...
Old Sep 24, 2003 | 12:39 AM
borin&strokin's Avatar
borin&strokin
Throttle Sticking
My 87 did the same thing. I cleaned and lubed the linkage REALLY REALLY WELL! and it quit. (that was in MN, so it was cold related, too). Start with brake kleen at the pedal, and work your way to the TB. Also spray the TB, and the IAC motor. Then go back and lube lightly. Cheers
Old Sep 24, 2003 | 01:05 AM
Jack01's Avatar
Jack01
Throttle Sticking
sound like your accelerator cable is gummed up clean the cable and relube with a lube the has a good viscosity at low temps.
wifes65
16
Sep 13, 2017 02:43 PM
99F350PS
Escape & Escape Hybrid
Oct 19, 2013 10:18 AM
hairyboxnoogle
Aug 16, 2011 11:04 AM
whalerron
Modular V8 (4.6L, 5.4L)
Jul 18, 2006 10:01 AM
ford-fanatic73
1997 - 2003 F150
Feb 3, 2004 07:37 PM
