cab leaking
Old Jan 16, 2005 | 01:20 PM
Ford from above's Avatar
Ford from above
Unhappy cab leaking
My 2001 F350 cab leaks when it rains heavy. It drips from passenger side handle up by the front window. Is this a normal problem for this year? I bought it used 6 months ago, so I don't know much of the history.
Old Jan 16, 2005 | 04:48 PM
hamster's Avatar
hamster
I noticed this same problem on my 01 F250 the other day when it rained pretty hard, thought it was just a freak thing until I read your post, guess I'll have to investigate it.
Don
Old Jan 16, 2005 | 05:22 PM
Ford from above
I thought it might be coming in on the top of truck right between the top of front window next to pass. door. I also parked backwards on a hill to where all the roof water went that direction. How is your power windows workin? My pass. side seems to be tempramental in the damp whether.
Old Jan 17, 2005 | 10:37 AM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Do you guys have cab lights? The water might be getting in there.
Old Jan 17, 2005 | 10:46 AM
The Grinch's Avatar
The Grinch
Remove the interior door panel and check the plastic vapor/liquid barrier that should be installed. It may be torn or have come off the door frame. It is supposed to keep any rain or condensation between the plastic and the metal skin and allow it to drip out through the drain holes in the bottom of the door. Thus keeping the interior dry...
Old Jan 17, 2005 | 06:32 PM
hamster's Avatar
hamster
I don't have cab lights on mine, (wish I did) but the water is coming in around the top of the door frame. When I noticed mine leaking it was all over the passenger armrest and above that point, the seat was also a bit splattered from water dripping down. Not sure if this the same problem Ford From Above is having. Haven't noticed any water on the inside from powerwashing or anything though.
Ford from above, I'm not sure about the window, think I've only used it once since I've owned the truck, if there is a problem I'll let you know.
Don
Old Jan 17, 2005 | 07:17 PM
aarontaht7.3L's Avatar
aarontaht7.3L
Question Same leak as you.
My 97 F250 leaks on the drivers side. Drips from the trim piece between the head liner and the windshield. Already ruled out the hole from the wire feeding the clearance lights. Any Suggestions? How hard is it to get to the bolt holes that hold the exterior sun visor? Anything I should know before I try? If it is the same leak as you guys and you don't have the visor, think it may be the windshield gasket?
Old Jan 17, 2005 | 08:21 PM
hamster's Avatar
hamster
I would vote for the visor on yours, I looked seriously at buying one (same year as yours) that had a visor on it and it had rained the night before I test drove it, the salesman apparently wiped all the water off the dash before we got there because the first corner we went around water came pouring out from under the dash all over the floor. Looking around you could see the gap around one of the mounting bolts where the silicone had peeled off.
Check your mounting holes real close, if it's not them, then yes, it would more than likely be leaking around the windshield.
Don
Old Jan 17, 2005 | 11:06 PM
Ford from above
I don't have cab lights either. Very interesting what the grinch had to say for me, because of my window problem too. Thanks guys. I'll try and keep you filled in, but might be a while
WVU
Oct 11, 2011 07:01 PM
arvtxrider1800
1997 - 2003 F150
Sep 10, 2009 09:37 AM
DHUB
2004 - 2008 F150
25
May 9, 2007 08:59 PM
2001gocougs
Nov 27, 2006 10:39 PM
elstx
Dec 28, 2003 09:38 PM
