Front axle???
Old Jan 16, 2005 | 11:27 AM
novadragman2005's Avatar
novadragman2005
Front axle???
I gots a 69 f100 wit a dana 60 out back stock, what front axles were available for this truck wit that back axle?
thnx
Old Jan 16, 2005 | 01:12 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Moved...
Old Jan 16, 2005 | 11:38 PM
Ford_Six's Avatar
Ford_Six
You have a five lug D60? I didn't think Ford put that in anything, just Dodge. For a front axle, it would be a D44 if it's a 4x4, or the twin I-beam if its 4x2.
Old Jan 17, 2005 | 03:10 PM
averagef250's Avatar
averagef250
Ford stopped using the semi-floater dana 60 in 64 as I recall. You should have the 9 inch in the rear and dana 44 in front.
Old Jan 17, 2005 | 07:34 PM
novadragman2005
i have to disaggre on whether u guys think its a nine inch, i have a facts manual that states as an option, the 69 f100's were available with a dana 60-3 limited slip axle which either contained 3.54 or 4.10 gears. also i know the difference between the nine inch and D60's (because i have one of each), but thank you for ur input
Old Jan 18, 2005 | 09:00 PM
fabmandelux's Avatar
fabmandelux
You are right! I have a 69 with a dana60 on the rear with 410,limited slip, and it has a 411 limited slip dana44 in front!
Old Jan 19, 2005 | 01:00 AM
68Mercury250Ranger's Avatar
68Mercury250Ranger
Have cut up several Dana 60 semi in old Fords, all were limited slip, all were 3.54 .
1 was a 64, the other 2 were 68 and 69. These diffs were not really much stronger than a 9", if at all. They sure caught my interest when I saw them, Kind of wierd like the Dana 44 rear in the 79 Ford F100s.
Old Jan 20, 2005 | 01:00 PM
fabmandelux
Question If you think thats weird.........
About 4 years ago I bought a 1978 ford E-350 4w4 that had TWO front drive lines[one for each side] .Turned out it was an expermental from ford and they only made 20 of them! Could not keep bevel gears from blowing out on the drive hubs. finaly gave up on them and installed a d-44 and different transfercase and sold it. sure wish I had kept the old parts. ford has done some strange stuff!!!
1993_f350_2013
13
Aug 16, 2015 04:53 PM
Baatzy
May 3, 2015 05:01 PM
ITDave
1997 - 2003 F150
Jul 11, 2012 02:08 AM
jgelfius
Jan 2, 2012 11:25 PM
jm5770
Mar 18, 2010 09:19 PM
