1984 susp.
Old Jan 16, 2005 | 03:41 AM
proud_redneck's Avatar
proud_redneck
1984 susp.
would a lift kit for an 84' F-250 work the same on aan 84' F-350? im looking at a 6 inch kit.
Old Jan 16, 2005 | 08:26 AM
iskerbibel's Avatar
iskerbibel
are you talking a body lift or a suspension lift? A body lift would work... not sure about a suspension lift.
Old Jan 16, 2005 | 11:21 AM
proud_redneck
suspension lift. i know some parts are able to be swapped, but i cant find a 6 inch kit for the f-350, only for the f-250.
Old Jan 16, 2005 | 01:32 PM
big hoss 29's Avatar
big hoss 29
F-250 and F-350 suspensions are the same until the F-350 went to a solid front axle in 86, so it should work.
Old Jan 16, 2005 | 01:46 PM
MontanaFord's Avatar
MontanaFord
keep in mind, it depends which TTB the f-250 has...ford ran the dana 44HD, and the dana 50...two totally separate front ends...when you look at them side by side, there's definitely some obvious differences...sheer size, on the 50's part, for one...lol...
MontanaFord
Old Jan 16, 2005 | 05:44 PM
proud_redneck
i went online and found a 6 inch lift kit for the f-250 from fuff-country, but i didnt see one for an f350, so im wondering if i can buy the 250 lift kit and put it on the 350
Old Jan 16, 2005 | 09:40 PM
big hoss 29
I believe the spring perches on all F-250's and 350's are the same width. I think that the only difference between a 250 and 350 are the axle ratings. They both have the same length springs, so new leaves will fit without having to move the shackles.
Old Jan 17, 2005 | 04:25 PM
proud_redneck
what about the steering parts that come with the kit, like the pitman arn. would those match up?
Old Jan 17, 2005 | 05:04 PM
bremen242's Avatar
bremen242
The '84 F250 and F350 have the same TTB suspension.
The only differences are that the F350 had a Dana 50TTB until '85.5 where it got a Dana 60 monobeam.
Old Jan 18, 2005 | 04:37 PM
proud_redneck
but you still think that the 6 inch lift kit from tuff country will work on my F-350 without any modifications. i dont know where i can get the extended brake lines for it though, cuz they dont come with the kit.
Old Jan 18, 2005 | 08:43 PM
bremen242's Avatar
bremen242
yes.
they have the same suspension.
www.jackit.com has extended brake lines. I'm sure there are several vendors that have them.
Old Jan 18, 2005 | 09:42 PM
proud_redneck
i just talked to a guy at an off road shop, and he said that the tuff country kit is a p.o.s. he told me that skyjacker makes a good quality kit, but i dont know how much its going to cost. the other kit was $900. how much do you think it should be?
Old Jan 19, 2005 | 06:41 AM
bremen242's Avatar
bremen242
skyjacker's kit will be more. It is a better kit. I'd use it if you plan on pounding your truck hard.
Old Jan 19, 2005 | 05:59 PM
proud_redneck
im putting 35xi6 inch boggers in the rear, and making it a super single in the rear instead of dually, and putting 35x10.50 boggers in the front on stock rims. would a 6 inch kit or a 4 inch kit be ok for it. if i can, id like to stick with a 4 inch, but im not sure.
Classic250
Jul 16, 2010 09:47 PM
zukezake
Car/truck Buying Advice
Mar 8, 2009 04:18 PM
HemiEater
Oct 3, 2007 06:43 PM
ozark1
Feb 16, 2007 08:26 PM
