Sponsored by: Real Truck
Parking brake adjustment
Old Jan 13, 2005 | 06:42 PM
250440's Avatar
250440
How do you adjust the parking brake on a 2000 super-duty? I push the pedal all the way to the floor and it will still roll.
Old Jan 13, 2005 | 07:06 PM
high ho silver's Avatar
high ho silver
Never had to tighten mine but did see a post here before that said someone took their SD in to the dealership and tech. pumped the emergency brake several times while holding out the release handle. Try that on yours.
Old Jan 13, 2005 | 07:29 PM
1ruralmailman's Avatar
1ruralmailman
get down under the beast, on the inside of the rear backing plate there is a rubber plug.pull that out and in there is a star adjuster,like was on the old drum brakes,use either a straight screwdiver,or a adjustment spoon to crank the slack out of it.count the clicks.and then do the other side the same number.it is easier to do if the rear is jacked up so you can check on it while you do it,do a few clicks then put the brake on see if the tire moves then proceed from there.
Old Oct 14, 2006 | 06:54 PM
micromack's Avatar
micromack
Parking Brake adjustment
I have a 2003 ford explorer. All books and info I've read says I should have a rubber plug on the back side of the rear wheel for adjusting the parking brake. I have none. After ripping off the rotor, destroying the parking brake shoes, I'm wondering if I should drill a hole behind the adjuster star so I can adjust these in the future. Should I do this or should I leave it as is? I fear the next time I need to do brakes on it that I'll be spending a ton of cash to replace the entire parking brake assembly next time. Thoughts?
rolloman
1997 - 2003 F150
Jun 14, 2020 11:44 PM
idealtrucks
2004 - 2008 F150
Jan 17, 2010 03:09 PM
61 uni
May 23, 2009 06:01 AM
lugnutt
Mar 6, 2009 08:38 PM
frankdude
Mar 3, 2008 02:37 PM
