1986 302 valve covers
Old Oct 8, 2002 | 03:14 PM
fishingboy's Avatar
fishingboy
Post 1986 302 valve covers
I need to change the valve cover gaskets on my '86 F 150. Evidently it is a big job. I can get the side under the air cleaner fairly easy, but the side under the injectors looks hard. Is there anything special I need to do, or are there any special tools I will need? If I succeed in getting them off, are there any adjustments I should make to the valves-the truck has 77K. Any info greatly appreciated. Thanks.......
Old Oct 8, 2002 | 09:14 PM
Franklin2's Avatar
Franklin2
The valves are not adjustable. Just change the gasket, and hope you don't break all the other junk you have to take off to get to it.
Old Oct 9, 2002 | 08:52 AM
fishingboy's Avatar
fishingboy
Do I need special tools besides a Torx for this job? Does anyone know the correct size Torx? Also whay gaskets will I need besides the valve cover gaskets? Thanks
Old Oct 9, 2002 | 08:45 PM
restorit's Avatar
restorit
Since you'll need to remove the upper intake manifold, you'll need a new gasket (to fit between it and the lower intake). You'll mostly need a 1/2" socket for the bolts (1/4" drive with extensions), with the exception of one smaller headed one and the one infamous Torx. It's a size T40, and it's very tricky. If you use a Torx T40 socket, don't try to use anything larger than a 1/4" drive, as it won't fit down between the two intake runners that the bolt is installed between. After buying a Craftsman 3/8" drive socket in this size and finding out when I got home that it wouldn't fit, I ended up using a cheap Lisle example that just would make it. I may try to replace it with an Allen head bolt, since there are many more options (example: T-handle set screw wrench) that can be used to reach it. This should be about everything, save for the socket to r & r the valve cover bolts. Now might be a good time to remove the throttle body and clean it and the idle air control valve, as well as checking / cleaning the EGR port / valve. If so desired, you'll need new gaskets for these, as well. Hope this helps!
Old Oct 9, 2002 | 09:39 PM
fishingboy's Avatar
fishingboy
Thanks for the replies. I may have gotten lucky: I replaced the drivers' side gasket and so far it is not leaking. It was messy enough just doing that one. I am not used to working on a vehicle while standing on a step-ladder. As long as it does not leak I will leave it as is. If I have more problems I will tackle the other one. Thanks again........
Old Oct 10, 2002 | 12:09 PM
Franklin2's Avatar
Franklin2
raerjim
18
Nov 15, 2010 04:37 PM
dan001978
Jul 12, 2008 06:03 PM
bigbadwolfe
Mar 11, 2007 05:56 AM
pipercoal
Modular V8 (4.6L, 5.4L)
Sep 18, 2006 06:31 PM
JBronco
1978 - 1996 Big Bronco
Oct 10, 2002 01:59 PM
