Clutch adjustment 91 explorer
Old Jan 13, 2005 | 05:06 PM
howhurley's Avatar
howhurley
Sorry this is so simple, but I need to know how to adjust the clutch in my 91 explorer. Is it a push or pull? It suddenly went from halfway disengage to floorboard ALMOST disengage and I need to do the work, if possible.
Any suggestions?
Old Jan 13, 2005 | 05:22 PM
mrshorty's Avatar
mrshorty
I thought these were non-adjustable hydraulic clutches. What does the fluid level look like?
Old Jan 13, 2005 | 07:25 PM
dybeepvw's Avatar
dybeepvw
Check fluid level in master cylinder resevior, make sure it is full, then bleed clutch according to procedure in Haynes Manual; that may resolve it or you could have a leak in the slave cylinder or bad master cylinder.
turp
Mar 23, 2014 01:55 PM
Melmo65
Nov 28, 2012 04:07 AM
wildmand
Aug 22, 2012 05:19 PM
19ktanker91
Oct 16, 2011 11:33 PM
phoneman91
Dec 6, 2005 11:50 AM
