Lifter preload ?
Old Jan 13, 2005 | 03:05 PM
460me's Avatar
460me
Lifter preload ?
I'am going to put a cam in for more torque.I hearing about a shim kit for pre load or convert to roller rocker.What will be the problem by just replacing the cam? 79' 460.This has been one hell of a learning experenice.
Old Jan 14, 2005 | 12:05 PM
greenhighboy's Avatar
greenhighboy
If you don't have the proper amount of pre load the cam will wear out quicker and may even wipe a lobe out during break in. The shim kit is the easiest way to do it for non adjustable rockers. I have used the ones from Crane.
Old Jan 14, 2005 | 02:13 PM
460me's Avatar
460me
Thanks.
I can get the cam,lifters,guide plates,studs and rockers for around $580.I just don't know if I want to go that route and money.If you want to play,you got to pay.
Old Jan 14, 2005 | 04:29 PM
greenhighboy
If it is something you just drive I wouldn't go to the trouble. For the money spent your not gonna get any noticable power increase. Use the money elsewhere. What heads does your motor have on it?
Old Jan 14, 2005 | 06:58 PM
460me's Avatar
460me
I haven't look yet,what ever is common with a '79.The motor hasn't been replaced.
Old Apr 27, 2005 | 03:59 PM
460me's Avatar
460me
heads are d8ve
crosshairs1972
General Automotive Discussion
Mar 26, 2008 01:44 PM
460mudtruck
Aug 31, 2006 07:36 PM
mike460
Mar 30, 2001 07:23 AM
