Aerostar Ford Aerostar
A/C Compressor
Old Jan 13, 2005 | 01:59 PM
RJAF's Avatar
RJAF
Question A/C Compressor
I have an 87 aerostar, 3.0, with dual A/C system. I converted the system over to 134 6 yrs ago and the performance was adaquate. I replaced the dryer/accumalator, low press switch and purged the system. Recently a line seal let lose and I lost the charge. After replacing the o rings in the system and evacuating it I can not get the system to accept more than 4 oz of 134. Low press is within operating parameters but I'm not sure what the high side is, compressor does cycle when defrost cycle is selected. Is the compressor failing? and if so is the model an FS-6. Thanks for any assistance.
Old Jan 13, 2005 | 02:53 PM
copper_90680's Avatar
copper_90680
Dump all the oil out, put in new oil and a new orifice tube.
1) Your orifice tube might be plugged op
2) Lots of oil in the accumulator prevents the system from being charged up
Had same problem. Also, if you are charing it yourself, you must rev the engine quite a bit to create enough suction to bring in the refrigerant.
Old Jan 13, 2005 | 03:21 PM
bell47g2's Avatar
bell47g2
a/c compresor
Are you trying to charge the unit with or without the compressor running?
Did you flush the system of all the old oil to begin with?
How long was it up and running before the line seal let go and which seal?
Old Jan 13, 2005 | 03:50 PM
RJAF's Avatar
RJAF
I'm charging the system with the unit running @ 2000 rpm, the sys was flushed prior to the conversion and replaced with esther oil, and replenshed after the recent evacuation, the system was running some 5.5 yrs and it was the seal going to the rear condenser.
Old Jan 13, 2005 | 06:50 PM
bell47g2's Avatar
bell47g2
Does the system cool OK?
Did you actually weigh the refrigerant into the system? 4 oz. isn't enough to charge the accumulator itself much less the whole system.
You may want to check the schrader valve at the charge port to make sure it is clear.
Infinite Monkeys
25
Jun 29, 2013 10:27 PM
win
Aug 4, 2012 06:08 PM
crabjoe
Apr 15, 2011 09:34 AM
firepop5
Jun 21, 2009 02:47 PM
Eddie
Sep 10, 2001 11:54 AM
