Sponsored by: Auxito
Whats a DPFE sensor
Old Jan 12, 2005 | 08:26 PM
mirageford's Avatar
mirageford
Whats a DPFE sensor
My son has a 98 F-150 4x4. 137,000 miles.
Engine light on,parts house read trouble codes,
P1405 "DPFE sensor up stream hose off or plugged"
Also p0171 & p0174 too lean bank one and two respectively.
Not sure what DPFE is and where to start.
Would appreciate any help!!
Old Jan 12, 2005 | 10:05 PM
damageinc's Avatar
damageinc
i dont know what it does, it has something to do with egr, mine threw a code, and it turned out to be a hose fell off. it is up by the throttle body, it has i think three hoses coming off of the bottom of it.
Old Jan 12, 2005 | 10:34 PM
LxMan1's Avatar
LxMan1
Welcome to the forums
It measures the egr flow to tell the PCM whether the egr system is working properly or not. They are known to fail.
Check the PCV hose assembly for cracks, Especially behind the intake in the elbow. Also a dirty MAF will cause the lean on both banks codes.
Old Jan 13, 2005 | 12:11 AM
Racerguy's Avatar
Racerguy
DPFE stands for Delta (or Differential, depends which book you're reading) Pressure Feedback EGR sensor.
This picture is from a Windstar but the sensor should look the same.
http://www.clubfte.com/users/racerguy/dpfe.gif
Follow the EGR tube from the driver's side exhaust manifold up to the EGR valve. Off the tube there are 2 hoses. The DPFE is at the top of the hoses.
Old Jan 13, 2005 | 09:57 PM
mirageford's Avatar
mirageford
Thanks guys, now I've got an idea where to start.
GreaseGun Joe
Oct 15, 2015 04:44 PM
deejdeej
1983 - 2012 Ranger & B-Series
Jun 10, 2010 09:51 PM
judgebc
Jan 4, 2010 12:50 AM
dkoenig
May 26, 2008 08:09 AM
cabo169
Feb 24, 2008 03:24 PM
