Sponsored by: Auxito
Door Ajar Warning Lamp
Old Jan 12, 2005 | 02:44 PM
EJ in CJ's Avatar
EJ in CJ
Does anyone know how to get the Door Ajar Lamp to go off when all doors are closed? Is there a switch in the door somewhere that needs replaced? Or is there a fuse or relay that has gone bad? This is a 1997 F-150.
Old Jan 12, 2005 | 02:55 PM
BillyBob69's Avatar
BillyBob69
Check one door at a time. Could be a switch that is being moved enough to allow the dome light to go out but not the door ajar light. try each one and press it by hand to see if it goes out.
Old Jan 12, 2005 | 02:57 PM
EJ in CJ's Avatar
EJ in CJ
Is there a switch in/on the door someplace?
Old Jan 12, 2005 | 03:09 PM
BillyBob69's Avatar
BillyBob69
I haven't looked at mine. I'll take a look...unless someone else here already knows.
Old Jan 12, 2005 | 03:14 PM
EJ in CJ's Avatar
EJ in CJ
Thanks, but I found the answer in FAQ's and it works properly now. Good ol WD40!!!
christaylor's Avatar
christaylor
WD-40 the latch mechanism on the jamb. Common problem with these trucks
Chris
socalarcade
1983 - 2012 Ranger & B-Series
Dec 12, 2010 05:17 PM
bohiaa
Feb 23, 2009 03:01 PM
PPrash
Mar 1, 2006 12:51 PM
cnoremac
Nov 13, 2002 10:06 PM
jkbhunter
Electrical Systems/Wiring
Mar 15, 2002 09:54 AM
