carb loading up when idling
Old Jan 11, 2005 | 08:24 PM
weldingfreak's Avatar
weldingfreak
went to start my truck the other day in the morning. when I let it warm it off for a while.It smelled rich and ran poorly for A while til, I ran it a while on the road then it cleared up. reved up smoothly after that.
Old Jan 12, 2005 | 09:43 PM
LxMan1's Avatar
LxMan1
Sounds like a bad case of carb icing. The moisture in the air freezes in the air bleeds and causes a really rich condition. After the engine warms up and the thermostat opens the warm air from the radiator thaws out the air bleeds and all is normal again. Usually the problem is a missing or non-functioning hot air system on the stock air cleaner.
It could also just be that the choke stuck closed, but it sounds like carb icing.
Old Jan 13, 2005 | 07:36 AM
weldingfreak
I have an open air cleaner on the truck, That could de the problem
Old Jan 13, 2005 | 11:38 PM
LxMan1's Avatar
LxMan1
Yep, both of my 77's do it with an open element breather below 50 degrees and damp or humid conditions and always when it is below 40.
Farmboypowerstroke
Nov 24, 2012 06:43 AM
Spocahp Anar
Sep 26, 2012 09:22 PM
JOHNNYRICH10
May 4, 2012 12:08 PM
Forddiesel17
Jan 4, 2012 08:52 AM
a857406
Feb 13, 2005 03:27 AM
