Invoice check
Block Labor
Rebore $108.00
Cam Bearing $22.00
Freeze Plugs $20.00
Weld Exhaust manifold $25.00
Mill exhaust manifolds $30.00
Crank
Grind $75.00
Cylinder Heads
Valve Job $98.00
Mill $44.00
8 Exhaust Seats $52.00
8 Exhaust Guides $44.00
Remove Broken Bolt $13.00
Grind Rockers $44.00
Grind flywheel $31.00
Parts
8 Exhaust Valves $52.48
8 Exhaust guides $22.32
8 Exhaust seats $54.96
Master parts kit $573.25
Master kit has:
Sealed power Moly Rings
Clevete Rod Bearings
Fel-Pro Gaskets
Federal Mogul Pistons
Clevete Main Bearings
Clevete Cam Bearings
Melling Oil Pump
Pioneer Freeze Plugs
Federal Mogul Pin Bushings
Clevete Cam
Stanodyne Lifters
Timing set
Total Labor $850.00
Total Parts $703.01
Sales Tax $57.95
Total $1611.00
Is this a good price or is it to much and what can I do Myself
