Aerostar Ford Aerostar
help with check engine codes
Old Jan 11, 2005 | 05:10 PM
jj2005's Avatar
jj2005
dose anyone know if their is a way to check the codes from my check engine light with out the tool? its a 1996 ford aerostar 3.0
Old Jan 11, 2005 | 06:34 PM
93nighthawk's Avatar
93nighthawk
'96 has OBD-II computer so the only way to scan it is with a scan tool.
You have two options.
1. Go out and spend $100 for a scan tool.
or
2. Go to an autoparts store (like Autozone) and they will pull your codes for free and tell you what they mean.
Old Jan 11, 2005 | 08:11 PM
himthere's Avatar
himthere
I have a pdf file describing how to pull codes without a scan tool. Seems quite simple. Also a html file with codes. Can email to you if you want. Tried doing it thru your profile but couldn;t paste into the message. I need an email address to send to using my normal email program. Gotta work 3rd shift. Can do tomorrow. (Its 9:15PM here now.)
Old Jan 12, 2005 | 12:25 PM
himthere's Avatar
himthere
I'm sorry, I didn't even look at the specifics of the PDF file I have. It pertains to the EEC-Iv control system. If yours is OBD-II then it won't work.
nitrored
1997 - 2003 F150
Oct 3, 2016 05:03 PM
riverratba
2004 - 2008 F150
Mar 26, 2010 06:24 AM
4x492150
May 6, 2009 08:39 AM
dallas4k
Modular V8 (4.6L, 5.4L)
Dec 11, 2004 11:08 PM
sokojoh
Bronco II
Jun 11, 2002 12:38 AM
