Bronco II Ford Bronco II
Check engine light
Old May 28, 2002 | 12:28 PM
sokojoh's Avatar
sokojoh
Check engine light
I read in someones message that the check engine light is used to read the engine diagnostics by the number of times it flashes. There are supposed to be codes related to the flashes, does anyone have a list or know where to find these lists of codes. Also how do you check for the codes?
Old May 28, 2002 | 03:58 PM
mrshorty's Avatar
mrshorty
Check engine light
[link:www.dalidesign.com/hbook/eectest.html|http://www.dalidesign.com/hbook/eectest.html] has the test procedure and a list of codes. Most any good manual (Haynes or Chiltons) will also have the test procedure and list of codes.
Old May 29, 2002 | 09:23 AM
gatorman41's Avatar
gatorman41
Check engine light
You also need an analog multitester. One that has the needle that swings to left and right. You can also buy a test tool that will output the codes and meanings. They are about $20 at auto part stores.
Old Jun 10, 2002 | 09:26 AM
ZCarSooner's Avatar
ZCarSooner
Check engine light
Save yourself the money! Go to Autozone and they will hook up a diagnostic machine to your ECU for free and tell you what's up!I did that yesterday in fact. It turned out to be the Oxygen sensor, I replaced it and all is well.
Mark
Old Jun 11, 2002 | 12:38 AM
topjymee's Avatar
topjymee
Check engine light
JimmiesVixey
Mar 1, 2017 08:03 PM
OldGoldie
32
Jan 17, 2017 08:28 PM
ImAGirl
Aug 3, 2015 03:13 AM
03KingRanchF250
Nov 15, 2006 03:30 PM
glk
Dec 15, 2003 12:42 PM
