Ica
Old Dec 9, 2004 | 01:43 PM
dallas4k's Avatar
dallas4k
Iac
I replace ICA reset the code and the check engine keep comming back P0505.
Old Dec 9, 2004 | 04:31 PM
LxMan1's Avatar
LxMan1
Is it idling fast? How does it run? What are you working on?
Old Dec 10, 2004 | 02:42 PM
dallas4k's Avatar
dallas4k
yes, and it idle at 900 in parking position.
Thanks
Old Dec 11, 2004 | 11:18 AM
LxMan1's Avatar
LxMan1
I wouls look for a vacuum leak somewhere. PCV hose behind the intake is known to crack.
Has anyone messed with the throttle stop screw on the throttlebody? If it is opened too far, the idle can't return to where it needs to be.
Old Dec 11, 2004 | 01:06 PM
dallas4k's Avatar
dallas4k
I took it to the local auto shop they try to adjust idle screw due to high idle. How do I adjust the idle screw to the factory setting? Thanks for your respond
Old Dec 11, 2004 | 11:08 PM
LxMan1's Avatar
LxMan1
A good rule of thumb is to back it off until it isn't touching the linkage. Then turn it back in until it just touches then go about 1/4 turn. See how it does. If it is too low, you can go 1/4 turn until it is about 650/700rpm.
nitro3421
N. California Chapter
Feb 17, 2017 08:54 PM
KsCop
Mar 6, 2014 10:42 AM
compman
Mar 3, 2014 05:19 PM
