What type of scan tool code reader do you recommend ?
Old Jan 11, 2005 | 06:10 AM
scholzee's Avatar
scholzee
I am looking for recommendations on a scan tool/ code reader. I have no problems with my 2001 Expy, but have an EVAP system problem with my 1996 S10 Blazer. features I want are IM readiness monitors, ablitity to read generic and specific codes, ability to read sensors outputs. Features I do not need CAN ready, programming for more HP, Also would like to spend no more than $250. All replies appreciated
Old Jan 11, 2005 | 01:06 PM
adelyser's Avatar
adelyser
I use the elm device from scantool[dot]net. It works quite well, and is very affordable.
Aaron
Old Jan 11, 2005 | 04:48 PM
buzzard's Avatar
buzzard
Check out autotap.com
Old Jan 11, 2005 | 06:18 PM
ExpyDaveG31's Avatar
ExpyDaveG31
If you have a laptop or notebook computer then I highly recommend the BR Diagnose program. You can download this for free. You will need to buy the cable for the serial port connection to the ODB plug. This costs $96 but the program can run various tests of your system and also pull codes and clear them. It checks O2 sensors and allows you to display gauge readings on the cpu so that you can see the readings while away from the dash. I use it on my 97 XJ and my Expy. This is compatible with Ford, GM, and Chrysler products. I am not too sure about the imports. I found out that I have a bad catalytic converter on Bank 1 and will be having replaced this week at the dealer. I'll do an edit and post the address shortly or you can use a search engine and put in BR diagnostic and look though the results. This is the harness with the necessary ends on it it.
Here is the link: http://obddiagnostics.com/
Old Jan 11, 2005 | 06:28 PM
keld's Avatar
keld
I have to admit that I am new at this, but so far I am real pleased with the Actron P9145, has generic code descriptions in the display, and includes a cd that will give you make specific code descriptions, costs is a little more though, about 280 plus tax at autozone,
EarthwiseScott
6.7L Power Stroke Diesel
Sep 28, 2016 10:06 AM
PaxtonShelby
Nov 12, 2014 03:58 PM
joegeds
Nov 4, 2014 10:41 AM
BrokenSockets
1997 - 2003 F150
Mar 9, 2006 09:27 AM
JR270
Mar 7, 2006 04:27 PM
