White STA alternator wire question?
Old Jan 10, 2005 | 11:18 PM
marcveinotte's Avatar
marcveinotte
Where the heck does it go? Is it switched? Is it a positive feed?
On the donor 79 truck it dissapears into the wire harness... in the 67 it's gone into it didn't have this wire ( or at least not this color and I have no idea what to hook it to. )
The Bat wire is self explanitory and the field wire(s) go to the regulator to be switched.
Help
Marc
Old Jan 10, 2005 | 11:44 PM
Phinxter's Avatar
Phinxter
This is the stator wire. What it is used for in my truck and my friends 66 mustang is a 12V source for the electric choke. Hope that helps
Old Jan 11, 2005 | 07:43 PM
Franklin2's Avatar
Franklin2
It is not used except for the choke if you have a factory ammeter harness.
It goes to the regulator as well as the choke if you have a factory alt light in the dash harness.
Old Jan 11, 2005 | 07:47 PM
marcveinotte
Hmm that is not the diagram I was working from..but it looks good. I will re check it when i get back to the shop tomorrow. So in other words it has nothing to do with alternator charge at all...
Old Jan 11, 2005 | 08:01 PM
Franklin2's Avatar
Franklin2
It does matter if you have an alternator light in the dash(the lower diagram).
If the truck you are swapping it into has the light in the dash, then you need to use the lower diagram, and it's harness that uses the "i" terminal. If you try to use the ammeter harness(top diagram) with a truck that has the light in the dash, it won't work right.
Old Jan 11, 2005 | 08:37 PM
marcveinotte
It's a 67 F250... with Ammeter... there was a large yellow wire to the reg, a large black wire to hot side of solonoid... another wire from reg to hot side of solonoid ( think now that should have gone to the I terminal..oops)..not that it's a huge deal I guess long as it's a positive feed.
I just had no idea what used to happen with the white wire( was different color on my 67 anyways I think it was green).. as the white I cut with a chunk of the 73-79 harness, dissapears into the wire harness( I guess donor truck had light not guage).. I was just wondering if I needed to hook that wire to anything. I have just swapped a Holley Avenger 670 carb on so I could now run that white wire to the carb I guess...
Old Jan 11, 2005 | 10:52 PM
Franklin2's Avatar
Franklin2
Well, you could try it, but it doesn't put out the same voltage as battery 12 volts. So if it doesn't seem to work right, go ahead and run a seperate 12 volt key on wire from the fuse box to the holley choke. The factory chokes are set up for the voltage from the alt stator output.
youngone1234
13
May 1, 2016 04:11 PM
lasthighboy
Jul 25, 2014 04:13 AM
idealtrucks
Aug 5, 2006 03:33 AM
78f250lj
Jul 3, 2002 06:21 PM
