97 ranger trouble
Old Jan 10, 2005 | 10:14 PM
DERANGED's Avatar
DERANGED
Unhappy 97 ranger trouble
My 97 has a 2.3 engine. Sometimes it will stutter and stall, but other times it will run fine. When it is acting up and you push the gas most of the time it will bog down. After it bogs down if you hold the gas it will backfire through the intake. Sometimes while riding down the road I can try to accelerate, and it feels like it has no power. I had the computer scanned and it did not show any sensors or anything wrong. PLEASE HELP if you might know the answer to my problem. THANKS TO ALL WHO REPLY.
Old Jan 10, 2005 | 11:01 PM
el conquistador's Avatar
el conquistador
sounds like you may have a bad plug wire, make sure they arent arching (look for the arching at night) also check the plugs.
Old Jan 14, 2005 | 07:47 PM
DERANGED's Avatar
DERANGED
thanx a lot i will check it do you think it may be a fuel regulator problem possibly
Old Jan 14, 2005 | 09:10 PM
Ken00's Avatar
Ken00
Checking the fuel pressure and pulling the codes woul be a good idea too.
Old Jan 14, 2005 | 11:48 PM
AlfredB1979's Avatar
AlfredB1979
There's a lot of things that could be. Throttle Position Sensor, maybe a timing gear jumped, who knows....
Something causing the truck to run *that* bad will normally set a code.
Old Jan 15, 2005 | 04:17 AM
dwildmanj's Avatar
dwildmanj
I had another Ford that would do that, and it was the fuel filter.
Old Jan 15, 2005 | 08:25 AM
the ranger's Avatar
the ranger
i had a ranger, a 88 one time with a 2.9 that acted just as yours does. and it was the timing chain, jumped two teeth. ran and drove, but had fits! with no power. replaced the chain and she was good as new!!!my advice , get rid of wind up you got, and go v-8. you'll love it and so will your truck. and its sooo much easier to work on...
Old Jan 15, 2005 | 07:28 PM
el conquistador
thats another thing to check, timing.
deranged, yours has a timing belt, though, on the front of the engine. pull the rubber plug on the outer timing cover and get the marks to line up on the cam pulley and the crank pulley at the same time.
how many miles are on the engine? has the timing belt ever been changed?
the ranger,
thats an awesome looking truck you got there. do you have any pics of the engine and all the mods you've done? there have been a lot of people on this forum wanting to convert their stock rangers to V8 rangers. looks like we know where to direct them now.
lvin4jc
44
Dec 6, 2014 11:29 PM
5th One
1997 - 2003 F150
Nov 12, 2014 06:57 AM
TPL33
6.7L Power Stroke Diesel
Sep 5, 2012 11:30 AM
awhite91
Aug 24, 2009 04:50 PM
bryan1856
1997 - 2003 F150
Feb 11, 2002 09:46 PM
