Ford Gold Remote Install
Old Jan 10, 2005 | 08:05 PM
fire19's Avatar
fire19
Unhappy Ford Gold Remote Install
I just had a Gold remote installed in my 2000 Ford F-350 Diesel at my local Dealer. There is a option called Qucik Stop that I wanted to use as a Turbo cooler( It runs the vehicle fo 10 Min.then shuts down) The dealer said that he needs a tach sense input. I was told that the 2000 does not have ths connection my friend told me that I could pick this up on the injector harness. The ford dealer said that lead is 118 volts AC and the tack sensor input is looking for a 12v input any ideas if there is a converter or where else I find the tach sense input ????
Thanks
Jim Bischoff
Old Jan 11, 2005 | 09:33 AM
HP junkie's Avatar
HP junkie
I just had a Viper alarm/remote start put in on sunday that has the turbo timer feature also. I can look to see if the schematic I have can help you locate the wire you are looking for. I also have a friend that installs these things for a living (he did mine) I could check with him to see if he can get schematic or has ideas.
Old Jan 11, 2005 | 01:31 PM
Mopey's Avatar
Mopey
The tach wire is white/pink stripe. It can be found at the powertrain control module and can be also be located in the main harness that runs through and along firewall to left of brake pedal. I just installed remote starter in my truck seems to work well.
Old Jan 11, 2005 | 09:36 PM
fire19's Avatar
fire19
Thanks for the info but where is the PCM ? I new to this type of vehicle and if it is under the dash how do you get to it ??
Thanks
Jim
Old Jan 11, 2005 | 09:52 PM
Mopey's Avatar
Mopey
Just find the wire in the bundle of wires that come in through firewall behind the brake pedal. There is a plastic cover overtop of the bundle for about 4-5 inches up the firewall, the wires then head up under the dash. They are taped up fairly tight but the tach wire was easy to find and pull out enough slack to tap into it.
Hope this helps.
Old Jan 12, 2005 | 08:03 PM
HP junkie's Avatar
HP junkie
Yes thats right. Sorry for the delayed response but we were just dumped on by old man winter, so I had to remove some snow today. We rec'd about 8 inches of wonderful white stuff. That's exactly what I was going to say, Thanks Mopey!
Lognomore
16
Feb 23, 2021 06:02 AM
resq302
Mar 4, 2012 07:32 PM
ITDave
2004 - 2008 F150
Apr 3, 2005 09:50 PM
bkampbel
Dec 9, 2004 11:17 AM
Squeaky Pulley
Electrical Systems/Wiring
30
May 6, 2004 02:52 PM
