cab molding
Old Jan 10, 2005 | 07:07 PM
olbud's Avatar
olbud
Question cab molding
hello friends how in the world do you get the molding off the cab.the the one that starts behind the door and goes up and over the windshield to the other side. on a 72 thanks olbud.
Old Jan 11, 2005 | 10:06 PM
idealtrucks's Avatar
idealtrucks
i just took a screwdriver and hammer and gently tapped it off
Old Jan 12, 2005 | 03:04 PM
Little Red 71's Avatar
Little Red 71
start with abig flat screw driver and gently pry or tap out starting at the end by the door handle with door openworking the bottom side of the trim out and up and work toward the windshield the tough part is if the windshield is in it is harder but take your time !!! cant say any thing about the re install as i have yet to install mine ??? i want to install a tinted shaded windshield first before i do the trim
Old Jan 12, 2005 | 04:06 PM
jwtimme's Avatar
jwtimme
an old style or flat type can opener works good, the one that puts a triangular hole in the can. you get good leverage and I wraped mine in take to keep from scratching the molding.
Old Jan 13, 2005 | 07:06 AM
dotcentral's Avatar
dotcentral
You may want to put something under whatever you use as a pry tool to keep from damaging the paint.
Old Jan 13, 2005 | 07:00 PM
oldeiron's Avatar
oldeiron
Little Red 71 think about doing the trim first. W/S is safer that way. I use rope like sm engine starter rope to pull rubber over pinch weld.
cirrusman
Jul 23, 2014 09:52 PM
Gary O
6.7L Power Stroke Diesel
Oct 20, 2010 04:18 PM
yukgoon
Jun 23, 2008 06:55 PM
rusbukt
Apr 2, 2008 08:09 PM
