Frame sections
Old Oct 30, 2002 | 10:09 PM
greginwindsor's Avatar
greginwindsor
Frame sections
Started on my 82 F-100 short flareside. Pulled the box and cab off and discover I have some framework to do. I've heard there are manufactures of frame sections. Any body know of this or do I just search the auto recyclers.
Old Oct 30, 2002 | 11:17 PM
cdd5599's Avatar
cdd5599
Frame sections
I have a frame lying around what do you need and where do you live.
Chuck
cdd5599@ksu.edu
Old Oct 31, 2002 | 06:06 PM
greginwindsor
Frame sections
Looking for that crossover piece located right behind the cab. Box mounts to it as well as gas tank. Live in Windsor Ontario area.
Old Nov 1, 2002 | 12:31 AM
cdd5599's Avatar
cdd5599
Frame sections
Well I have all that but i live in Kansas so i Don't know if it would be worth it to ship it. Email me if your still interested.
cdd5599@ksu.edu
Chuck
Old Nov 2, 2002 | 10:02 AM
bremen242's Avatar
bremen242
Frame sections
best to do is go search the junkyards (if there is many in canada).
as far as i have seen, anything from 80-96 with fit, and f-150/250/350 are the same. try to get something from 90 and above. at least that is where you need to start down here in PA.
9 chances out of 10, you'll have to remove it yourself. if you dont have a torch, best way to do remove the rivets are X'ing the top with a grinder with a cutoff wheel, and then knocking the pieces off with an air chisel. then use the air chisel (with a straight punch) and knocking it out.. (sometimes they are hard, but they will come out, make sure you dont bend the cross member, they are kinda fimsy).
when I did they ones on my f-250, I alsocut the legs off (took the rivets off), and took they away to be sandblasted and painted with good PPG paint, and bolt everything back together. (i use grade 8 bolts to be sure, but you probably only need grade 3 or 5).
sorry if I gave you to much info.
Old Nov 2, 2002 | 09:00 PM
greginwindsor
Frame sections
No such thing as too much information. Thanks for your help, I'll give it a try.
Old Nov 3, 2002 | 02:12 PM
Ford_Six's Avatar
Ford_Six
Frame sections
